Thread: Spread bore or Siamese
    Jul 2010
    My engine number is 11700022 going by the manual it was the 22 nd RHD engine built in 1957 and should have been in a 88 petrol not a 109. Is this a spread bore or a Siamese bore? My gearbox number is 170616442 and was built in 1956 and is the correct for a 109 that year. My chassis number is 123800791 and is a 1958 109 . It was sold by Annand & Thompson in Brisbane . Are there any records from there still available.
    Mike
    If it was made in 57 it will be a spreadbore.
    Logan Village area S.E. QLD
    All records from Annand & Thompson were lost in the Brisbane floods of 1974 So the only thing you can go by is the plate on the radiator support panel, if you have a plate, not a lot of those there either
    Mrs hh
    Series Landy Rescue
    Our FB Page..
    Jul 2009
    S.E.Qld
    Quote Originally Posted by Defender Mike View Post
    Mike
    According to my L/R workshop manual No.4291 1957 88" 109" and station wagons didn't have separate engine numbers.Why do you think yours should be in an 88"? .W.
    Jul 2010
    Because my workshop manual says so
    My original workshop manual printed March 1960 says so 1957 RHD engine numbers start at 1170001 ( ) 88 inch petrol.LHD models started with 114700001. Miune was the 22 nd engine built.
    Mike
    Jul 2010
    1958 .............
    1958 109 inch Series 1 petrol RHD start at 111800001 . Acording to the workshop manual printed March 1960.
    Oct 2007
    Red Cliffs
    Back to simply methods if the oil filter is on the right then its spread and if it is not then it is siamese.
    Apr 2002
    Godwin Beach 4511
    32.38 MB
    Quote Originally Posted by dennisS1 View Post
    from the drivers seat or from the front of the car
    2007 Discovery 3 SE7 TDV6 2.7
    2012 SZ Territory TX 2.7 TDCi
    Jul 2010
    What he said ^
    Oct 2007
    Red Cliffs
    Side
    I might be a bit different in the way I look at things, But I truly believe that a car only has one right side regardless of which way it is traveling.
    Plus on most siamese engines there will be no oil filter at all, having been long removed.
    Dennis
