28th June 2013, 10:34 AM
Hayman Reece locking pin keys
Hi
My P38 has a Hayman Reece towbar and the towhitch is connected with a locking pin, unfortunately I didn't get the key with the car
I have rung Hayman Reece, but they were no help, so I took it to the local locksmith who punched the number stamped on the lock into his computer but said nothing came up under Hayman Reece
I was wondering if anyone else had any suggestions except to cut the old one off and buy a new one !
Steve
Note to mods, if this is in the wrong forum, please move it, I couldn't find any other area i thought sensible to post in.
28th June 2013, 11:12 AM
There are different brands of those locking pins - have a look on ebay and you may be able to identify the brand and follow it up from there:
trailer hitch lock | eBay
If not, can you get a drill in there to drill out the centre and then you should be able to pull it apart. If not you may be able to cut the shaft with a thin angle grinder blade depending on access. Can't really do that with an ARB RR Classic bar though as there is almost no access.
Bob
28th June 2013, 11:20 AM
Bob,
Thanks for that, looks like a replacement pin is the way to go.
I have a high speed air cutter which should make short work of the pin
Steve
