Results 1 to 10 of 16
Thread: paint confusion, what to use?
    Jan 2013
    melbourne
    Whilst my 61 SWB is in drydock awaiting funds for a new engine, I have taken liberty with it and started refurbishing panels and such.
    I am rebuilding NOT restoring.
    I have got to the stage now where all the little bits are done (interior cleaned and painted, windscreen regalved, new glass, door tops, etc.) Now comes the big things. I have taken the roof off and stripped it ready to paint and the body is pretty close as well.
    Question is what paint do I use? inside is simply spray enamel which will hold up ok but outside I am confused. I have read and re-read "how to paint your car" and the more I read, the more my brain hurts.
    any ideas out there?
    Narrogin WA
    Enamel is relatively cheap and safe to use; gives a gloss similar to the original paint; tends not to last well especially in the sun; gives a nice finish off the gun; needs a mist-coat first to help the topcoat stick and not sag.
    Acrylic is usually more expensive; requires more thinner, which adds to the expense; is a very durable finish and in that respect is better than enamel; needs cutting back with wet & dry paper and power-polishing to get a smooth finish and shine; is generally more time-consuming than using enamel; is safe to use, provided that like enamel, one follows the safety directions.
    Two-pack paints are very durable; give a brilliant gloss off the gun; have nasty isocyanates in them especially when using a hardener and therefore are dangerous to use without a full-flow air supply to the face. Not recommended for home use!
    Cheers Charlie
    Jan 2013
    melbourne
    Thanks Chazza, there is no rush so acrylic it is. I will look into it more. thanks for your help.
    South Sydney
    We do all ours in two pack with a charcoal filtered mask. I would recommend it over anything else. We paint our cars in the home workshop btw.
    Will
    Narrogin WA
    Quote Originally Posted by MR LR jnr. View Post
    I have had a refreshing read of the National OHS Commission MSDS here http://www.safeworkaustralia.gov.au/...socyanates.pdf
    I recommend that anyone who is using, or wants to use isocyanate paints, has a read of it in particular pages 4 and 9. I had forgotten that isocyanates irritate the eyes and skin, as well as being a toxin.
    Unfortunately Will, your charcoal cannister is not removing the poison before it gets into your lungs,
    Cheers Charlie
    99.87 MB
    I used Rustguard paints with a roller for the blue ute.
    Slunnie
    Apr 2002
    Godwin Beach 4511
    32.43 MB
    the army use alkaloid enamel
    so did i...
    2007 Discovery 3 SE7 TDV6 2.7
    2012 SZ Territory TX 2.7 TDCi
    Feb 2013
    Ballarat,Vic,Aus
    Will
    NNNOOOOooooooooo...... 2pack it really bad stuff, it's not just breathing it, it's absorbed by the skin, particularly the eyes. Don't even dream of painting this stuff in a closed up shed...
    The biggest problem however is acrylic laquer is crap. No-where else in the world seems to use it except for Australia (I think it's pretty much outlawed in industry due to the amount of overspray).
    My suggestion is to make yourself a small builders plastic booth. Pressurise this with a blower. I grabbed a charcoal mask a few years back and modified it so I could blow fresh air into it. My fresh air ?? An cars radiator fan in a box, blowing air down a hose to the mask. It worked amazingly well. The force applied by the fan wasn't enough to open the exhaust valves on the mask, but supplied fresh untainted air. Of course you also need to wear fully sealing painters goggles... I wear double nitro gloves (not latex that dissolves) too. Painters suites are really cheap, and you can chuck 'em or clean them when done.
    2pack paints really are the only thing worth using, but whatever you do, do NOT under any circumstances paint them in a closed up shed without a fresh air supply. Protect your eyes and any bare skin.
    Have look around autobody 101 forums. The seppos really do know there sh!+ They sure do argue about everything though.
    http://www.autobody101.com/forums/
    On these american forums:
    single stage == 2pack urethane, but it's the glossy colour that doesn't require a clear ( So there's only "one" stage to apply). I think the local paint shop here refers to it as "common".
    BC/CC == Base coat (a satin finished coating) ... this offers no protection at all and usually has a tiny recoat window for clear. You then must apply clear over this coloured base coat. They also refer to it as "2stage" ... base and clear.
    seeya,
    Shane L.
    South Sydney
    When I said workshop, I meant that we work out of home, painting occurs on the driveway...
    Have to look into all the safety stuff though, I thought panel beaters only used charcoal masks, dad does all our painting I'll get home to read it.
    Will
    Feb 2013
    Ballarat,Vic,Aus
    Will
    No way does anyone in industry wear charcoal filters. They spray in booths that recycle the air so quickly, so can't even see overspray in them.
    Take a look at this youtube clip. This is what spray painters wear with these modern paints. If your thinking "space suite" your not far from wrong.
    [ame=http://www.youtube.com/watch?v=QLH83B0Q2qE]SATA - How to paint correctly - YouTube[/ame]
    the urethane paints with hardeners really are nasty. I reckon for an old land rover enamel would look right. The problem is it'll take all day to dry, so you'll need somewhere that won't atract bugs and dust ( these can find there way into my home made booth.
    seeya,
    Shane L.
