I'm struggling to find a good comparison image to post for you.
Hop on google and look at images for Landrover Salisbury axle.
Apart from the size (Sals is physically much larger than rover diff), the key difference is the construction. Sals has a huge cast center housing, with the axle tubes pressed into it. Rover diffs are welded together from metal pressings so don't have have the perfectly round axle tubes.
Steve
				1985 County - Isuzu 4bd1 with HX30W turbo, LT95, 255/85-16 KM2's
1988 120 with rust and potential
1999 300tdi 130 single cab - "stock as bro"
2003 D2a Td5 - the boss's daily drive
