Thread: First Project
    County Steve Guest
    First Project
    Hi all,
    I have dragged a Series II tray back off of a farm as a first project. I have little mechanical knowledge but was hoping the simplicity of these vehicles maybe a good place to start. Possibly I was wrong.
    I have purchased restoration and mechanical manuals but have hit a speed bump before even starting. All the manuals seem to assume that the vehicle is operational before the project starts.
    Steps like ensure all spider webs are cleared away from work areas are sadly lacking.
    I'm hoping someone can point me in the right direction to find a process to get me to where the books start.
    The vehicle has no key and no battery as a start.
    Are there any recommendations before trying to start something that hasnt been started for possibly a long time.
    What sort of fuel ? I read that standard unleaded was not an issue.
    I am starting to build a process but any thoughts, warnings or inspirations would be greatly appreciated.
    Steve
    JDNSW's Avatar
    A good start would be to do as much reading as possible in this forum. Note that almost anything in the Series 3 forum also applies to Series 2/2a, as does quite a lot in Series 1.
    I would start by giving the vehicle a thorough clean, including degreasing. Removing the floor and transmission tunnel is worthwhile at this stage.
    An early step would be to see if the engine is a goer (it probably is, unless bits are missing, even if it does not run very well).
    First check that the fuel tank will hold fuel, put a few gallons in and see if the priming lever on the pump will deliver fuel to the carburetter. (And if not, why not). Drain the oil and refill, drain and refill the cooling system, checking for leaks. At this stage a battery can be fitted, being careful to check for shorts (most circuits are unfused!). All being well, it should then be possible to start the engine.
    You are likely to find that both clutch and brake hydraulics will need attention before attempting to move it. As a farm hack, it will probably have been taken out of service because of a fault that did not seem worth fixing - the most likely is a clutch hydraulic failure, but other candidates would be lack of brakes, serious steering problems, broken exhaust manifold, broken half axle.
    Having established the actual state of the vehicle, you then have to decide what you are going to do with it - full restoration, restore as necessary, but keep original, restore as a daily driver, modifying as seems desirable, etc.etc.
    Hope this helps
    Dec 2012
    Sunshine Coast, QLD
    me too
    Hi Steve,
    As a newbie like yourself, working on my first project - a '67 SWB 2a - I heartily endorse John's recommendations. I have spent hours trawling through the discussions on the AULRO forums and feel like I actually now know a thing or two!
    It has helped me to go in a few weeks from a complete LR virgin to someone who can talk with a reasonable amount of knowledge with my mechanic about my project vehicle and not feel like a complete prat.
    Apart from engine/drivetrain issues, you will need to get a good look at the chassis and check its condition. When you strip down the body, label and bag all fixings and small components so you know where they came from and inspect each body part as you go. The steel bits will probably need attention for rust, the aluminium bits will probably be ok. The chassis is likely to need some work, a complete sand and repaint at the very least, and some repairs are likely necessary. That's where I'm up to at the moment.
    It's all a bit daunting, but great fun so far.
    Best of luck with it. Any pics we could have a look at?
    Jul 2012
    midwest W.A
    G'day Steve, I'm going through the re-build thing as well, complete strip down. My advise would to take heaps of pics at every step to refer back to when time comes to put back together.
    Enjoy
    Gold Coast QLD
    Hi Steve
    Can't agree more with the last 2 comments, bag & tag EVERYTHING, zip lock sandwich bags are a God send and take photo's!! gotta put photo's up. Dont be afraid to ask questions as there is a shed load of knowledge here. Have a look at "Operation Ralph" here & "Operation Smeg" in the Series 3 forum (my builds) if you like. I actually used Dynamo and hot water straight from the laundry washing machine tap to de-grease Ralph and it works a treat, Just don't do it on any good painted concrete surfaces as it bleaches it. I did it on the road.
    Cheers Ian
    1964, S2a SWB "Ralph"
    1977, S3 SWB "Smeg" (Gone)
    1996 D1 300tdi auto (Gone)
    1973 Rangie Classic (Gone)
    2012, 110 (Series 12) Puma "The Tardis"
    1962 109" Tray Back "Ernie"
    1998 D1 300tdi (Dizzy)
    2017 Kawasaki Versys 1000
    You must now cut down the tallest tree in the forest... With... A HERRING!!!!!
    Nov 2010
    I started a quick fix on a 73 SWB about six months ago knowing absolutely nothing about cars but once I started taking a few things off I didn't stop and so have ended up embarking on a complete restoration. Having stripped the car down to a chassis i can now confidently say I am in no way prepared to put it back together, but by following the advice already provided to you I am confident it will come together eventually.
    I especially liked and have followed the taking photos advice. Before removing anything I took plenty of photos so I have been able to reference them when trying to fix things. It makes it much easier to put things back together if you have a photo of what it should look like.
    Nov 2007
    Gold coast
    I hold my hands up to anyone who's never done a restoration or rebuild, its a big ask at first but you will soon learn things, some things will be hard and best left to the experts, some hard things that would normally be left to the experts you will do with ease. You will learn loads, and be a happy Landy owner.
    If you have the time, take it to the bones and work up to a rebuild. It will be worth it in the end.
    And of course if you need any Series parts, give Landybitz a call....
