5th July 2013, 01:05 PM
rear windows not working
can anyone help rear windows not working have checked fuses window ecu checked ok console switchs checked ok dont no were to look next
5th July 2013, 11:16 PM
Hey Mate,
Your next step is probably to pull the door skins off and test if the motors are getting any juice when you press the switches.
If the power is getting there than it's likely the motors are gone. If it isn't, unfortunately what you have mentioned as checked already are really the only other things that could cause this issue.
Might mean re-checking those things, sorry.
Chris
5th July 2013, 11:46 PM
Try taking the switch from the working back window and try that in the other.
The consol switch won't work the windows if the window door switch is gone.
Ask me how i no...
Paul
