Results 1 to 10 of 14
Thread: Asiana Flight 214
    BigBlackDog Guest
    Asiana Flight 214
    'Surreal' escape: How survivors fled badly damaged Asiana Flight 214 - U.S. News
    Amazing that all those people made it out alive, sad those 2 young girls didn't make it.
    Pictures of the runway looks like the tail clipped the sea wall and that was the end of it. Other reports said it came down very steep, tail down. Will be interesting to see how and why this happened. More lessons to be learnt the hard way
    Nov 2007
    Gold coast
    Early suggestions are the plane hit the end of the runway...
    Sep 2012
    Adelaide Hills
    any landing you walk away from is a good one.
    any landing where the plane is reusable is a great one.
    sheerluck Guest
    Quote Originally Posted by Eevo View Post
    I think they've failed on both those counts, with 2 fatalities known so far.
    And that airframe is a total loss.
    Sounds like the cabin crew did a great job in the evacuation, I'm sure the casualty list would have been much longer otherwise.
    Sep 2012
    Adelaide Hills
    Quote Originally Posted by sheerluck View Post
    yes indeed.
    i also heard a member of the flight crew who survived was flung out of the plane and onto the ground.
    BigBlackDog Guest
    The outcome could have been a lot worse had they hit that wall a few feet further up the body.
    New 777 retails for about 300 million depending on which one you get, that's an expensive day in the office if you ignor the human cost
    Jan 2011
    Here's an excellent set ob observations of the trajectory of the aircraft, well presented.
    http://flyingprofessors.net/what-hap...-flight-214-2/
    It doesn't explain why it happened though, but as a former instructor of Korean pilots, my money is on a stuffed up visual approach.
    Australia
    Agreeing with Stallie.
    There always hindsight, yet the crew should probably have recognised a bad profile quite a few miles before the gear was left behind on the sea wall.
    Nov 2007
    Gold coast
    It seems one of the deceased was run over by a fire truck..
    Avoca Beach
    I am amazed at how well the 777 held together in the crash with the wings still on when it came to rest, and the fuselage basically intact. Although the video wasn't clear it also appears that most of the seats stayed in place.
    It seems that the wing tanks did not catch fire , and the eventual fire was relatively minor compared to what is commonplace.
    Compare that with the DC10 at Sioux City United 232 back in the 80s. a completely different result but probably going a lot faster.
    Regards Philip A
