Results 1 to 10 of 15
Thread: Losing Brake Fluid after Mechanic Bleeded Brakes
    Jan 2013
    NSW
    Red face Losing Brake Fluid after Mechanic Bleeded Brakes
    Hi all,
    I had my mechanic bleed my brakes last week as they were a little spongy, I checked after it was done and the brake fluid was full.
    This arvo when i got in to start the car I had no pressure in the pedal and when I checked the fluid it was empty.
    I refilled the fluid and pumped the pedal and it kept going straight to the floor.
    Caught a cab to work
    Came home tonight and the fluid has dropped a little from where it was but there is pressure back into the brake pedal!
    So my question is what do you think has caused this?
    Is it possible that the mechanic had left the bleeder nipple nut open and fluid has been slowly leaking out?
    OR
    Is it likely that I have ripped a brake hose off somewhere?
    OR
    Is it something else entirely?
    Im fairly mechanical but have little experience with Rovers, when bleeding the system is it just the 4 wheels that have bleeders?
    Thanks for any advice!
    Jan 2013
    Penrith
    Did you see any fluid on the ground or on the wheel, ?
    not an uncommon failure.
    with the vehicle stationary and chocked pump the brakes a few times. look on the ground for fresh brake fluid. Im tipping you wont find any.
    Where its going is into the brake booster.
    Whats most likely happened is that as part of the bleeding the brakes the MC pistons have been made to move past their normal range of movement, and the aged seals have lifted on the lip thats been worn into the MC. Thats let the brake fluid out.
    To test theory remove the vac line on the booster and very carefully insert a long ziptie in a downwards direction through the hole if it comes up wet with brake fluid you have failing seals on the MC.
    Dont drive it till you fix this, once it happens once it can happen again at any time without any warning.
    Jan 2013
    NSW
    Thanks Heaps Dave.
    If it is the master seals is that an easy fix?
    Just rebuild the booster?
    Define easy?
    for me yes, its easy. and takes about 2 hours go to woah to
    strip out the MC+ booster,
    clean the booster
    Strip the MC
    hone it if required and make the judgement on replace/repair
    reseal it
    put it all back
    bleed the brakes.
    Jan 2013
    NSW
    So I couldnt get away with just doing the seal?
    only if you're willing to accept a higher risk of brake failure than doing the job properly.
    the difference in time saving from just doing the seal as opposed to doing the extra 3 or 4 things required to do the full job is maybe 15 minutes.
    it takes about 2 minutes to put a brush hone down a MC to get it ready to take new seals (you have no choice but to strip it down this far anyway)
    it takes about 10-12 minutes to undo the 2 nuts and pin holding the booster in place, clean it via hosing out the vac side to get rid of the brake fluid thats trapped in there then put it back in.
    Crafers West South Australia
    Another common failure is the seal at the base of the reservoir, the one nearest the booster. If the mechanic moved the reservoir at all, the perished seal breaks and all the fluid runs out down the face of the booster. (Yes I did this and finally found a source for this seal.) Its the dogleg section of the seal that supplies fluid to the port recessed into the face of the booster, the rubber here is very thin.
    There is a brake shop in SA that stocks these seals loose. They will post.
    Power Brakes South Australia for brake parts and service you can't get anywhere else
    It takes about 15 mins to do, although its very fiddly to get the bottom bit lined up.
    Jan 2013
    NSW
    Ok Im going to pull the booster apart right now. Im sure Im going to have some questions!
    Jan 2013
    NSW
    OK so now Im really lost.
    I pulled the master cylinder of the brake booster (2x 13mm bolts) and found nothing in the booster? I had a good look and dipped a cable tie all around and there is no fluid and no evidence that fluid was ever there???
    I again checked all wheels and ran all lines from the cylinder to the proportioning valve and then to the wheels and I didn't find anything!
    There is no sign of a leak around the booster/master cylinder itself either
    This truck leaks diff oil, transmission fluid and oil but I cant find any brake fluid!!!
    Any advice as to where I should go from here?
