The best performing antenna I have ever had on a vehicle was a gutter mounted 3db steel whip on a ground independant base.
generally speaking a higher positioned lower gain antenna will out perform a bullbar mounted higher gain unit.
Roof racks are OK as long as the antenna is ground independant. Otherwise you are back to drilling a hole in the middle of your roof as we did in the good old days.......
Regards,
Tote
