Page 1 of 5 123 ... LastLast
Results 1 to 10 of 43
Thread: Better than a 4BD1?
    Landiheaven Guest
    Better than a 4BD1?
    How would one of these rate over the Isuzu 4bd1?
    15b toyota diesel to lt85 land rover conversion | Trade Me
    Thinking it would go straight in to my 110 trayback
    Feb 2012
    Parkdale, Melbourne
    You could try, but the Landy chassis might reject it like an unwanted organ transplant.
    - Justin
    '95 Disco 300TDI - sold
    '86 County 110 Isuzu
    2006 Range Rover Vogue td6
    Quote Originally Posted by Landiheaven View Post
    On the way to the tip I'm assuming.
    with those numbers youd be just as well off with a tdi300.
    Kiwiland
    There was a 4BD1T on tardme a month back for $2k. Almost bought it myself.
    The 14BT and 15BT are good engines, the 15BT having better technology and larger displacement than a 4BD1T, but relies on some electronics. However the height (overhead cams) and the exhaust location on the RH side could be big problems.
    The NA, 15B is a poor substitute.
    Landiheaven Guest
    Quote Originally Posted by Dougal View Post
    You mean that 4BD1 that was set up for a marine application Dougal? I was looking very seriously at that 4BE1 3.6 and Nissan mq patrol box setup that was in a SIIA 109.
    Kiwiland
    Yes. But all it really had was an intercooler bolted to the top, a rebuild of completely unknown quality and it was an 85/86 model like mine. So other than a swap in spare it wasn't any benefit to me.
    4BE1 and 4BD1T are largely interchangable. So if you get a setup for one, it's no problem to upgrade later.
    Landiheaven Guest
    4BD1 and T's are bloody expensive over here and we don't have the luxury of Isuzu Bellhousings to mate to the LT95/85
    Kiwiland
    Would you be interested in an Isuzu MSA-5P gearbox (factory Isuzu 4BD1T box) with adapter shaft into LT230 and gear lever adapted to the "long stick" position of the early LT77?
    Jul 2011
    Yarrawonga, Vic
    Horrible looking bellhousing to bellhousing, conversion why not just use a Toyota gearbox and transfer case if your going to use a Toyota donk !
