                                                12th July 2013, 09:01 AM
			Puma alarm
					How do i unhook alarm its comming on for no reason.
                                                12th July 2013, 09:04 AM
					Is the horn going off or is it just the RED led on the dash?
 The alarm can be triggered by faulty door locks - for example if the door is not locking via the remote, then if you open the door the alarm will go off.
 I don't think you can remove the alarm - so you need to fix whatever is triggering it
                                                12th July 2013, 09:16 AM
					Misty rain sets it going . Can i unhook horn
                                                12th July 2013, 11:10 AM
                                                #4
					It's being caused by the door switches.
 Bend the strike plate on each door in a little(including the rear door).
 Also spray each trigger with WD or Inox and work them in and out a few times.
 You should be right
                                                12th July 2013, 11:11 AM
                                                #5
					Sounds like a short on a door or bonnet switch.
 Yes you could just pull the horn in a inch - but this will only addressable symptom.
