12th July 2013, 11:48 AM
130 Wheels on a 110 Puma
Hi,
I was given a set of rims off a 96 130 for my 110 Puma.
I am trying to fit these and the fronts went on ok, but when I went to drive it there was a squealing noise from the rear and a bit of juddering.
When I took one of them back off there was a shiney spot on my brake (caliper I think) and it had rubbed some of the powercoating from the supports on the inside of them rim.
Has anyone else used these on a Puma 110, or is the offset totally wrong for my vehicle?
thanks
Richard
12th July 2013, 05:33 PM
It could be that you have a slightly bent stone guard making the noise? I've had 130 wolf rims on my 110 ute with no problems..
12th July 2013, 06:27 PM
12th July 2013, 08:38 PM
#4
FWIW later 130 rims use a shallower well in the rim and a welded centre (and higher load rating) so no rubbing.
12th July 2013, 09:56 PM
#5
I wasn't sure if they had changed them, but I might just get a big hammer out and tap the corners dowm gently.
I have put the alloys back on for the weekend for now.
Thanks for the replies.
Richard
