Results 1 to 8 of 8
Thread: Engine Watchdog - Where to mount sensor on engine (TD5)
    Jul 2011
    perth
    Hi all,
    I have just picked up a TM4 engine watch dog, i would just like to what which bolt people have used for the sensor "O"-ring; and what temperatures are people setting for their max?
    As the TM4 also comes with the low oil pressure alarm, i would also like to know which wire to tap into behind the dash.
    Jul 2010
    Cairns
    Hi, I just attached mine to one of the inlet manifold bolts. I figured that once I knew the temps that were normal then it becomes relative to that.
    Driving across the Barkly in January this year I saw it climb as the outside temp got in the mid forties. It got to 86 deg but driving in normal temps in Darwin and Cairns is about68-74
    Gary
    Jul 2011
    perth
    Quote Originally Posted by garyper View Post
    Gary
    Thanks for that garry, i ended up pushing the sensor through a grommet behind the gauge cluster, and will mount the device on the right side where there is a nice surface at the right angle for viewing. As for the location of the sensor, what i did was remove the top bolt of the rear left hoist point on the engine, please let me know if this is a bad idea.
    Know the only thing i need to know is which wire to splice into for the low oil pressure alarm.
    Aug 2009
    Sunbury Victoria
    Quote Originally Posted by technophile View Post
    I put mine on this point but I find it is a bit slow to react. I thing the steel lifting point takes longer to change temp. I was going to move it to somewhere where it is straight on the alloy head or remove the steel bracket.
    Cheers, David.
    My Land Rover has made me a better Mechanic........
    D2 TD5 Manual, CDL, Detroit Rear, Truetac Front, 2" OME lift, 32" MT Tyres, ARB Bull Bar, Winch, TJM Roof Rack, Driving Lights, Dual Batteries, ARB Side Steps, Rear Draws, Uhf.
    Jul 2011
    perth
    Quote Originally Posted by Landover View Post
    I put mine between the head and the bracket, not between the bracket and the bolt head. I assume you did the latter?
    Aug 2009
    Sunbury Victoria
    No I put it against the alloy head under the bracket. I maybe wrong but it was just an observation.
    Edit: On second thought I will have to check in the morning to confirm.
    Cheers, David.
    Jul 2011
    perth
    After some research i think i have found the correct wire to splice into for the Oil pressure switch to warning light; I believe it is the White/ Brown wire.
    But before i go and do it, it would be great to get some confirmation from someone in the know,
    thanks
    May 2010
    Gisborne
    I put my temperature sensor where my mechanic advised me to place it.
    There is a threaded hole at the back of the engine about 15cm below the rocker cover gasket. It's a good spot as it is away from the manifold and appears to provide a good consistent reading.
    I also started off by placing it where you did, but also found it heated up too slow.
    From memory I think it's a 7mm thread.
    Normal operating temp for my td5 is between 75 & 79.
    In summer the temp gets a little over 81.
