Results 1 to 10 of 15
Thread: Land Rover Series II SWB 88" 1960 Utility
    Jul 2013
    And a Journey begins on road to restoration !!
    Any suggestions on where to start for parts from usual chassis and other bits and pieces!!!
    Thanks in advance!!
    Forty minutes closer to the hills in a house the bank is kind enough to let me live in
    Seeing that makes me wish I was shorter.
    Look forward to updates.
    smurf village
    looks quite good.
    the uk is good but you have a ok land rover place is melbourne at blackwood or blackburn, they have a good catalog and are easy to order off and are quite reasonable priced but just need to be a bit careful you get the right parts.
    Narre Warren South
    4 Wheel Drives in Blackburn have a good range of new and secondhand parts. Land Rover Parts and Accessories
    They carry the same aftermarket parts as everyone else (Britpart, Bearmach etc.) but will also source parts from local suppliers. Some rubber parts are suspect (same as other suppliers because they are mostly all made in India).
    The alternative is to ship from the UK. Much cheaper (even though shipping can double the UK cost) but you'll often be getting the same quality as 4 Wheel drives supply.
    Some UK suppliers list both genuine Land Rover parts and pattern parts.
    I've had good service from LR Series and Paddocks. Pegasus have a lot of parts re-manufactured but I experienced a long delay getting parts plus they didn't have credit card facilities. There are lots of other UK suppliers.
    Land Rover Parts | Range Rover Spares - Accessories | Paddock
    L. R. Series - specialists in land rover, land rover series and range rover - gearbox, axle, transmission parts, spares and major units
    Pegasus Parts remanufacture new Land-Rover bulkheads for Series models.
    Best of luck,
    Colin
    '65 Series IIa Dormobile
    '70 SIIa GS
    '76 SIII 88" (Isuzu C240)
    '81 SIII FFR
    '95 Defender Tanami
    Motorcycles :-
    Jan 2013
    Central Australia
    You would be surprised how many parts you will still be able to get from your nearest Land Rover dealer. Whether or not they still have the old parts books is a different matter though!
    Well done on the purchase
    Jul 2013
    Thanks Colin
    Thanks for the tip i will check them out. I was thinking of getting chassis from UK apprentlly, it can be imported for $1000 plus whatever chassis cost.
    Let see i have plenty of time not rushing into anything
    Regards,
    Nav
    Jul 2013
    Thanks for all the appreciation fella's. Will post updates as they come
    JDNSW's Avatar
    I've found Fred Smith in North Wantirna a surprisingly good source of parts.
    Narre Warren South
    Quote Originally Posted by reachjatt View Post
    Thanks Colin
    Thanks for the tip i will check them out. I was thinking of getting chassis from UK apparently, it can be imported for $1000 plus whatever chassis cost.
    Regards,
    Nav
    I remember someone on the forum imported a chassis a while back, I'm sure it worked out just over $3K.
    How bad is your chassis ? Can it be repaired ? There's lots of threads on here covering chassis repairs. If you have room it might be worth looking out for a 'parts car'. Often vehicles turn up with good chassis'.
    Colin
    PS: I also use Fred Smith in Bayswater (30 Havelock Road). Tends to be a bit more expensive for s/h parts and if you visit personally you need to allow a couple of hours......
    '70 SIIa GS
    '81 SIII FFR
    '95 Defender Tanami
    Motorcycles :-
    smurf village
    You can get a galvanised chassis from richards chassis Prices
    I personally would buy a wreck with a good chassis.
