Results 1 to 10 of 16
Thread: 6 Speed D3 box to LT230 ??
    Jul 2011
    Yarrawonga, Vic
    What is / Who makes the D3 Manual Gearbox , not a MT82 by the looks
    Check out this guys project to fit a 6 speed box into his Defender with a GMC 6.5 Tdi in front , (don't like his cut & shut output shaft , tick tick )
    I'd have been happy with a 2.7 tdci V6 in front.
    proves you can fit anything to anything.
    Land Rover Owner • View topic - my project, disco 3 6 spd box to LT230 conversion
    now that I think the Ford Territory uses the jag 2.7 Tdci and MT-82, hmmm
    Kiwiland
    The 6sp manual to LT230 has already been done by a UK mob. But they put a decent engine in front, the 2.7 TDV6 (jag version), not a poxy 6.5.
    I was looking for info on the D3 6sp box the other day. Found nothing.
    But ratios from the D3 brochure:
    1 5.08
    2 2.8
    3 1.78
    4 1.26
    5 1.0
    6 0.835
    R 4.73
    Final drive 3.07
    Transfer 1/2.93
    Compared to Defender MT82 ratios they are pretty close:
    Transmission GFT MT-82 six speed manual
    Full time four wheel drive
    Transmission
    (high/low) : 1 Overall Gearing
    (High/Low Range)
    1st 5.443 23.334/62.988
    2nd 2.839 12.171/32.854
    3rd 1.721 7.378/19.916
    4th 1.223 5.243/14.153
    5th 1.000 4.287/11.572
    6th 0.742 3.181/8.587
    Reverse 4.935 21.156/57.109
    Final drive ratio : 1 3.540
    High range transfer box ratio 1.211
    Low range transfer box ratio 3.269
    Quote Originally Posted by Dougal View Post
    1 5.08
    2 2.8
    3 1.78
    4 1.26
    5 1.0
    6 0.835
    R 4.73
    Final drive 3.07
    Transfer 1/2.93
    are you saying the D3 6 speed manual has been mated to a lt230?
    Kingston, Tassie, OZ.
    ZF IIRC Don.
    don't use the pathetic clutch they have, too small for a d3. check out the complaints http://www.car4play.com/forum/post/index.htm't=1200
    and yes i have done one, and yes they are totally mismatched for that vehicle application IMO.
    JC
    Kiwiland
    Quote Originally Posted by uninformed View Post
    Yes
    http://bellautoservices.co.uk/wp-con...r-TDV6-LRO.pdf
    Dec 2009
    Williamstown, Barossa, SA
    Forget that ceramic friction disk too.... 30000kms and the disk will still be like new, and the flywheel will have a matching grove all the way around it! Used to fit them to the bricky forklift tractor conversions at request of owners, and we'd be replacing the flywheel, friction disk and clutch cover a year later back to standard!
    St Helena,Melbourne
    1.13 MB
    Dont think we get any manual D3's in OZ, wonder what box they use ? Edit: Just saw JC's comment.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    Jul 2011
    Yarrawonga, Vic
    There is a Manual on carsales
    2005 Land Rover Discovery 3 SE
    I love the last line of the ad,
    at least if it blows up you can't get them for false advertising
    ****Land Rover Discovery 3 SE TDV6 MANUAL - 7 Seater - Beautifully presented with full service history, this 1 owner Discovery is extremely Rare - being a manual, let alone an SE. All setup and ready to go - comes with bull bar and driving lights, UHF radio and electric brakes, tow bar, compressor and much much more. All the SE options as well including Rear aircon, parking sensors, adjustable suspension, leather interior.....Make an enquiry for more information. With 3500 towing capacity - this is the ideal touring vehcile and will not last.
    preston
    Gold
    X2!!!
    JC
