Results 1 to 10 of 19
Thread: workshop air compressor
    sydney
    HI
    My air compressor just given up teh ghost, anybody got any recomendations or experinace of recently buying.
    like all things i dont want to spend too much, missed out on last weeks aldi deal but have seen couple else were.
    Stanley Air Compressor - Belt Drive, 2.5HP - Supercheap Auto Australia
    C327 | RAV2.75/36 Air Compressor | machineryhouse.com.au
    whats your thoughts and ideas, i do general workshop stuff, been using a direct drive supercheap blackridge, worked fine and did pretty much everything i wanted.
    ian
    Aug 2010
    Sunbury, VIC
    Quote Originally Posted by muddymech View Post
    ian
    Apart from living to a ripe old age? Personally, I think buying cheap compressors is a false economy, they WILL die quickly, even if only used from time to time. Every time I go to the tip, there are heaps of cheapies being chucked away.
    If you only want cheap, they fine - pretty much anything will do what you want. If you want something that will always go when you turn it on, and outlive you, then you will need to spend a bit more.
    How many cheapies are you prepared to throw away over your lifetime?
    For a few hundred more than that Stanley unit you would be able to get something that would last a long time.
    Oct 2003
    Godwin Beach Qld
    I would suggest a twin cylinder belt drive unit like those available from "Trade Tools Direct" if you have those stores near you. Www.tradetoolsdirect.com.au
    Geelong, VIC
    x2 - belt drive allows you to replace the head or motor separately should one of them fail.
    Steve
    1985 County - Isuzu 4bd1 with HX30W turbo, LT95, 255/85-16 KM2's
    1988 120 with rust and potential
    1999 300tdi 130 single cab - "stock as bro"
    2003 D2a Td5 - the boss's daily drive
    Jun 2013
    North Brisbane
    As a builder for almost 25yrs, my compressors spat out millions of 4inch nails. The best ive had and still have is from trade tools direct QLD. Theyre heavy, but worth their money (at least the old ones were). They used to be cheap as well but havent kept up on prices lately. I have their framing guns that have had millions of nails run through them without any maintenance, still going strong but can get stuck just like every other brand.
    Shepparton
    As suggested go for a belt drive. Compressors and motors can be changed seperately. Buy the biggest CFM you can afford - there are two ratings free flow - as to what comes out of the air hose and compressor - ability to fill the tank. When comparing CFM make sure you compare CFM at the same psi.
    I have an Air Mac (12months old), they are used alot in the orchard industry around where I live.
    Keep your old tank and join it too your new compressor for more volume.
    Davehoos Guest
    I have a near new 40L 2.5 horse compressor.
    cost $15 at recycle center.
    I purchased $30 hose and fittings from aldi.
    it just pumps up 1 car tyre from flat or 4 mower tyres.
    my truck compressor has a 11.5 electric start Honda and about 120L with 3/8 and 3/4 hose--has an Australian made logo but is at least 80-90's.
    the motor and compressor purchased seporatly from a compressor specialist.we have a variety of similar looking hydrolic drive units on varies vehicles.
    dad purchased a 120CFM broomwade for a few hundred.ideal for air chisel and random sander.
    May 2006
    Woolgoolga
    30 year old McMillan, still going strong considering, just starting to chuff a bit of air out the side, was going to replace it, but for a few bucks I think I can give it a new lease of life. Buy quality I say
    May 2009
    Tatura, Vic
    Quote Originally Posted by Vern View Post
    Mine is 28 years old, although not a McMillan I suspect it is the same. It is three cyl. It has sat under my bench and never had an oil change. I had to change the belts recently and at the same time removed the plug(first time) to drain water.
    It is used often and still going strong.
    Dave.
    I was asked " Is it ignorance or apathy?" I replied "I don't know and I don't care."
    1983 RR gone (wish I kept it)
    1996 TDI ES.
    2003 TD5 HSE
    1987 Isuzu County
    sydney
    thanks everyone, i have gone with the best i could afford from trade tools
    ian
