Results 1 to 10 of 20
Thread: Windscreen No4!
    May 2010
    Dongara area on the Mid West Coast WA
    Windscreen No4!
    O.K. I have now run out of expletives to describe my frustration!
    You could call it poor luck but I now have a crack running across my windscreen yet again. In two of the cases no issue as the rock/s that came in my direction were big enough. The last two however the stones were 'quite small' and would have no doubt caused a 'star crack' on my D2 that could be repaired rather than replaced. These screens are expensive and my insurance company has paid for two and when this is over I will have paid for two. All in less than two years.
    It makes me think that these D4 windscreens are under some sort of stress during manufacture. As they were all LR genuine screens I am left wondering if the generic non OEM screens may be a little tougher???
    Oh well, as someone before me said 'Such is Life'!
    On the matter of replacement I won't get it replaced where I live. The two companies who do this work in my regional centre have had a go on both my D4 and D2 previously with, let's say, poor results.
    So Perth here we come to get the windscreen replaced. Can someone please point me to a reliable, D4 experienced, windscreen company or bloke?
    Mar 2007
    South Arm, Tasmania
    Don't know who to recommend in Perth - but I'd steer clear of the company that claims to do "instant" replacements.
    They did mine in Kalgoorlie - broke some / most of the clips holding the black plastic strips on the sides of the screen in place, and re-fitted same strips using either broken clips or cheap ones from the local Super Crap Auto store. Next trip back to Perth, both strips came off (luckily they will not come right out as the bonnet has to be open for this).
    I removed the strips completely and continued driving - it's bloody noisy without them on.
    Went to the dealers when I got back down here and bought new clips for both sides (plus a full set of spares) and re-fitted the black plastic dress strips myself.
    Genuine LR clips are yellow - the cheap ones are usually white.
    If you're chasing a contact in Perth who should be able to recommend someone good, try Steve Armor at Lifestyle 4WD - he would have some good contacts. Phone number is 9271 7900. I've got to ring him myself this morning as I've just got a message from my young bloke in Kalgoorlie that the alternator on his D2 has just crapped itself.
    Cheers .........
    BMKAL
    Apr 2011
    Coffs Harbour
    LGM. The D4 screen is very weak along the bottom below the wiper blades. As with mine all it took was a small stone to bounce off from that area and a stress riser will occur. It was a tiny chip. The crack will then happen without warning one day while negotiating the shopping centre speed bumps.
    This is what has happened to mine and when I get home eventually I will put some clear tape (I use aircraft leading edge protective tape which is out of date, but will do the job) along the lower blackout areas, leaving the wipers clear. Hopefully it will absorb the impact enough in this weak area.
    I also got a bullseye directly in front of me but there was no cracking from that. Caused by a moron who, because I pulled left and slowed down, decided that it was OK for him to stay in the middle of the road at 100kmh and shower me with stones. Dont get me started on those type of people. .
    2012 Fuji White 3.0 D4, Rear view camera, Hi-line sound, E-diff, Xenon lights, ARB winch bar, Lightforce 240 50w HID. Brads sliders.
    May 2010
    Tape it Up
    Thanks Plane Fixer, I like the idea of the 'Leading Edge' tape or someting like that, that can absorb a little of the shock!
    I do know what you mean about inconsiderate people and rock showers.
    Jul 2010
    WA
    LGM - Unlike the kal experience, I've had good job (twice in last 12 months!) from the instant mob in ossie park for my D4. They seem to do a few, and have been very attentive to VIN, which is more than I could say for the local LR stealer, who just kept supplying the wrong glass (4 times). So, no matter where you go,insist on triple checking the VIN match. My insurance has been right up to the mark - one free in each 12months period of insurance cover. And BTW: instant means a full day, on the D4. Good luck.
    Quote Originally Posted by trevorj View Post
    I'm looking for a new windscreen too. What is their name?
    Edit: Nevermind, I understand now - 'Instant Windscreens'
    2024 RRS on the road
    2011 D4 3.0 in the drive way
    1999 D2 V8, in heaven
    1984 RRC, in hell
    Mar 2012
    Wait Awhile
    with my experience not only do you need the right window, but also you know your speaking the right window installer when they say "Oh I will need to also order all the replacement clips for your side strips as some usually break." if they don't I don't use them.
    Feb 2012
    Wollongong
    I've just had windscreen number 3 (in 8 years) installed. The original screen got a crack from a bit of coal on the highway; number 2 (Shatterprufe brand) copped so many chips over 3 years it was not funny and then recently copped 3 big ones from one stone so game over for it; number 3 is back to the OEM Pilkington screen ... so happy, installer has done a lovely job, changed clips (had recently fitted new A-Pillar mouldings as my old ones were falling apart) and top moulding, fits perfectly, clear and most noticably is significantly quieter in the car than the last one (ie. can no longer hear my engine running inside the car when sitting in the garage).
    On the subject of toughness, I recently had a side front window broken by a theif, the cops couldn't believe the damage done to the door trying to smash the window and in the end they only managed to make a hole big enough to get the stuff off the front seat ... damaged front door and back door in the process. The cops remarked that it seemed like a much tougher job for the scumbags than usual. Tint probably helped also.
    May 2010
    Good to know
    Epic pooh,
    Its good to know that the D4 is tough nut to crack when it comes to bad guys & girls (no sexisim here).
    PostHistory,
    That's one of the problems. The average windscreen guy can no doubt install the glass but is the its the other detail bits that beat them. There's nothing like your 'A' pillar trim coming off at 110km/h. In my experience they go off with a bang and its good luck if you can find it when you get to turn around.
    Oct 2007
    Brisbane West
    It will be the laminate - the aftermarket tinting - that caused the difficulties for them getting in. Very tough stuff.
