Results 1 to 10 of 30
Thread: High compression vs low compression
    Dec 2012
    Perth, WA
    Hi,
    Rather than hijack a thread, I'll ask in a new one.
    This will sound possibly like a dumb question, but, what is the difference between a high compression engine and a low compression engine?
    Is my 2001 4.6 I believe it is a Thor engine high or low compression? Can it be either? What is the difference? If it is low compression how can I make it high compression? What are the advantages?
    Sorry abut all the questions, I just feel a bit confused?
    Steve
    The compression ratio will be written above the engine number on the tab on the side of the top of engine block on the passenger side between the two centre exhaust pipes.
    It should have a 8.3 or a 9.3 (please correct me if the numbers out not quite correct) above the engine number indicating the compression ratio.
    The two engines are basically the same except for the pistons - so to upgrade from low compression to high compression you would need to change the pistons.
    As a general rule HC will produce more power and more torque.
    Crafers West South Australia
    [ame="http://en.wikipedia.org/wiki/Compression_ratio"]Compression ratio - Wikipedia, the free encyclopedia[/ame]
    Feb 2013
    Gosford, NSW, Australia
    Hi,
    Also remember that a higher compression engine requires higher octane fuel to run it.
    As with everything, there are tradeoffs
    The other thing you may care to read about is power vs torque, motors can be tuned in various ways to provide more of one or the other.
    Have fun!
    Steve
    Aug 2010
    Pakenham
    Quote Originally Posted by intheozone View Post
    Hi,
    Steve
    Hey Steve
    There's a good chance that yours will be a Low comp motor as that was standard that the P38 was set up for the Oz market, however some High comp motor did slip through.
    Dec 2012
    Perth, WA
    Thanks guys,
    I am just looking to squeeze a few more horses under the bonnet, looking for inexpensive ways do do this.
    I think a twin pipe exhaust system may help and make her sound a bit more V8ish
    Aug 2008
    Staying on topic, I am hijacking! Sorry intheozone. My 3.5 has a psi reading of 120 -125 on all cylinders. I'm told this is low? I went looking for the number on the block but couldn't find it. I will look again.
    Here is a pic of the engine number and compression ratio on the side of a 3.9 block. If only the engine number is there, the block has been leveled at some stage and the numbers removed - the engine number would have been stamped back on.
    You can see the compression is CR 8.13:1
    Here is a pic that shows where the numbers can be found - left side between the two middle exhaust ports.
    Aug 2008
    Thanks Gary, what does that mean? I was expecting a PSI reading, so not sure how to interpret or convert it.
    Just checked, and interestingly I have the engine number but not the compression numbers. Why would the block be leveled?
    Jez
    Feb 2013
    Quote Originally Posted by snowbound View Post
    Jez
    Hi Jez
    It is a ratio so it is expressed as 8:1 or 7:1 etc, this is different from compression pressure, which is measured in PSI.
    You can do a rough conversion, as detailed here
    How do you convert compression ratio and psi
    But as it says there are other factors involved in the actual pressure you finish up with
    Steve
