Results 1 to 10 of 15
Thread: Gear Box had it. 02 td5
    Aug 2010
    Tennant Creek
    Dearest Landrover Brains trust,
    Was doing a gearbox oil change today. When I noticed there was no oil in the box!!!!!!!!!! Went to fill and it poured out of a hole Possible crack in the housing. See Photo attached. Can I weld it up and see how it goes?
    Paul
    Jimboomba, QLD
    Going by your photos, I think perhaps you were trying to drain oil out of the bell housing (which shouldn't have oil in it) and filling the same. The plugs shown in the photos are wading plugs. The gearbox drain and fill points are much further back along the gearbox.
    Do you have a RAVE disc or other workshop manual?
    -- Paul --
    | '99 Discovery Td5 5spd man with a td5inside remap | doesn't know what it is in for ...
    | '94 Discovery Tdi 5spd man | going ... GONE
    they are indeed the blanking plugs for the bell housing.
    the drain for the gearbox is further back. on the right hand side
    Jul 2009
    Lake Macquarie NSW
    X2.
    Robbo
    Jan 2010
    classic face palm... at least its good news!
    Jul 2011
    Yarrawonga, Vic
    Gold
    Aug 2011
    Quote Originally Posted by manic View Post
    So long as it didn't go anywhere near the clutch plate...
    Mar 2013
    Gymea
    At least you know there's a good chance the gearbox is alright.
    Jan 2012
    Now in Sunny Perth
    Clutch may be slip slip slipping now though
    Mar 2013
    Gymea
    I'm guessing, but others may respond with a big NO, that you can spray brake cleaner or contact cleaner in there but there may be a bearing that you have to be careful not to dry out with the spray. Hopefully you don't have to pull it apart to clean it.
    Fingers crossed someone has a solution.
