Results 1 to 10 of 16
Thread: Inspection pit
    Jun 2010
    Warragul
    Inspection pit
    Hi all, I've been interested in putting a pit in my shed for a while. (replaced the R380 in my disco twice) so I've been doing some research dampness is an obvious problem but I live on top of a hill so surely the water table will be on my side. as is ventilation and drainage, but in my internet travels I've come across things like this... Mech Mate - Motors Pits | Mech Mate Garage Flooring - Motor Pits But for the life of me I cannot find anything like it in Australia. In a perfect world I'd have a four post hoist. but unfortunately the shed's not quite tall enough and I cant see me being allowed to sell the house for a bigger shed or "improve" the shed in an upwards manner. any tips or even these prefabbed liners in OZ would be a GREAT help..
    May 2008
    Bundaberg Qld
    Not sure about Vic,but check your local council as pits in sheds have quite a few rules attached to them up here.
    Jul 2011
    Yarrawonga, Vic
    Go to Seymour Exchange and strike up a freindship with linesman, 2 x telstra 6 pits , stacked on top of each other, job done
    (9 pit would be better, but a special order, I was in Telstra 30 years & never saw one)
    http://www.viscount.com.au/products_...ation_products
    Aug 2010
    Sunbury, VIC
    Quote Originally Posted by pop058 View Post
    Good thought there - i have been thinking of putting a pit in my garage too. I have just checked our Council website, but I can find nothing there. I might ring them and see if I can get any sense out of them.
    If I do, I'll be doing it the old fashioned way and digging a hole and concreting it. I helped a friend a few years back to this, and it turned out well but was a lot of hard yakka...
    Jun 2010
    Warragul
    how'd you ventilate it?
    If I do, I'll be doing it the old fashioned way and digging a hole and concreting it. I helped a friend a few years back to this, and it turned out well but was a lot of hard yakka...[/QUOTE]
    Aug 2010
    Sunbury, VIC
    It wasn't ventilated. It was used with the garage door open, and we were never stupid enough to get in it while a car was running on it. We mounted a 40 watt Fluro in each side, and a solid bit of angle iron was welded to a frame that was cast into the concrete on the top rim which a jack adaptor was made up to fit so you could jack up the car from any position easily and safely.
    Pity it is so far away from me now as I used to service all my cars on it.
    Jun 2010
    Warragul
    well thats easy I can open the door, I really like the jack adapter plate idea. Might steal that one. any other ideas like that keep em coming thanks
    Quote Originally Posted by bacicat View Post
    Cranbourne North
    Had a pit in the garage of our old house. Was only a shallow pit, say half depth. You could not stand under a car, but you could sit comfortably . One thing I do remember. What ever you remove, as in a gear box and it is in the pit you will need a hoist to get it out. So make sure you have a lifting point above the pit. You could say that it is one of the pit falls of having a pit. I no I no my humour is just the pits.
    Cheers Hall
    Oct 2003
    Godwin Beach Qld
    My old boss when I was driving school buses built a pit to service the buses,hand dug,with a heavy angle iron rim and built in fluro's and power points,as well as a rolling jack base,and a little portable pump to remove any water seapage,the floor had a slight dip and drain, like those round grids used with outdoor driveway gutters, was mighty for doing general maintance and brake lining/wheel bearing servicing,full depth with a steel ladder at one end,only problem was with heavy rain it would part fill with water/seapage and if a cane toad fell in, then it would "click" it's distress call all night
    Jan 2012
    Manly, NSW
    Tanking Solution
    I knew a friend over in the UK who built one in his shed. He was into American Muscle Cars. His house was not on a hill and damp and water was going to be a problem as he was digging lower than the house damp course.
    He was advised to use Tanking Solution. It comes as a powder like cement to mix and you apply it like a grey slurry. It's creates a water proof inch think solid barrier which can then be rendered or painted over.
    I used some myself in my UK home on the floor of an extention.
    Not sure if you can get it here but it works great.
