Results 1 to 10 of 19
Thread: Help! Any carpenters here?
    Sussex Inlet. N.S.W.
    My usual woodworking problems have struck again. I am fitting double swing doors into an opening. Measured opening at 1680mm Two doors at 820 equals 1640mm So far so good. Measure thickness of jamb at 18mm where door sits. Times 2 equals 36mm so I have 4mm to play with. Darn, the doors will not fit opening, They OVERLAP almost 10mm. So now I have to trim the doors about 6mm each to get them to fit with a gap in the centre. This I shudder at doing even though I have a table saw. I am too scared to do it for fear of wrecking the doors. I cannot remove the jambs as they are fixed in place and square and vertical. Should I just do it or chicken out? My woodworking problem is that everything I do I never leave enough clearance and all my jobs are too tight and have to be recut etc to make them fit. I measure too accurately and cut the same. Jim
    Jim VK2MAD
    '17 Isuzu D-Max
    Torres Straits
    Perhaps you could plane 3mm off both long faces - will appear more balanced than 6 off the non hinge surface (depending on door design of coourse).
    3mm with a good sharp plane shouldnt take too long and less chance of a table saw horror show!
    S
    Normanhurst, NSW
    Maybe you're losing a bit on the hinge side. Are your hinges recessed correctly?
    Otherwise agree with 'roverrescue' re taking a bit off each side of each door.
    Roger
    Apr 2010
    dawesveill
    forget the doors, hang a curtain rail and hang hippy beads! go back to drinking beer!
    Thanks guys. I taped up the door edges and ran them through the saw. I don't know why I was so hesitant. At least I now have a new skill...turning good bits of wood into sawdust. Jim
    Jim VK2MAD
    '17 Isuzu D-Max
    Feb 2009
    Heathridge, W.A.
    You're obviously extremely lucky to have a perfectly square and plumb doorframe!! Very rare those!!
    it normally goes something like this:
    frame opening = door width x2 + jamb thickness x2 + 9-10mm for 3 gaps + 15-20mm for frame to jamb gaps.
    The 9-10mm for 3 gaps I refer to is the gap down each hinge side and the gap in the middle. I like to shoot for a nice 3mm gap at hinges and up to 4 in between the doors. Reason being this allows for paint and future swelling/movement etc. Good quality hinges are normally about 2.5mm gap anyway. The reason you need a touch more down the middle of the doors as when both doors are opened simultaneously, they get longer due to arc being scribed and pivot point of hinge, so to speak, and can bind if not the right gap. Obviously you don't want a big gap that looks like poo.
    you need gap between the frame and jamb as no frame is perfect straight or plumb and you need to be able to adjust the jamb to suit the doors. Even if your floor was dead level and frame perfect, the doors may not be....
    now remember if you have rebated doors you need to measure of the same face or you could end up making your jamb and opening too wide or too narrow. If you do not have rebated doors you need to know if you are using some sort of plant on stop on one of the doors and if this needs to be allowed for.
    Planning the doors would have been preferred than the table saw, but what ever works is best in the end.
    Thanks all. Doors hung in place and all is good. Jim
    Jim VK2MAD
    '17 Isuzu D-Max
    Jun 2013
    North Brisbane
    For the next time. Scribe the marking with a razorblade/stanley knife, before you cut, (will help with any chipping). Also at that small amount, it would have been easier to plane off excess.
    Door jambs are usually 19 or 20mm, but that depends on your timber, I know NSW leans to using meranti, but here in QLD we tend to use pine, so slightly thinner. Jambs don't necessarily sit hard against the studs, they can sometimes add 2mm plus.
    Try using hirline hinges for an easier fit rather than checking out into the door.
    Glad to hear you did it. Always is more satisfying when you can do things youself. (Even if the neighbourhood may have heard)
    Jambs are measured at their thickest point. So XXX (for width) x 30 or 40 x 35/38/44 depending on if they're internal or external doors, material is immaterial.
