Results 1 to 10 of 18
Thread: 3.9 V8 - Power loss Issue and Engine Dieing! Wierd Noise After
    Jan 2013
    NSW
    Angry 3.9 V8 - Power loss Issue and Engine Dieing! Wierd Noise After
    Hi all,
    I have bought this disco a couple of months ago and I have been experiencing this intermittent loss of power issue. It can go weeks between it happening. Sometimes the engine dies sometimes i can save it by flooring the accelerator, sometimes I get the engine light on sometimes not?
    Today I lost power and pulled over, and the engine died, I put the car in drive and without turning the ignition off there was this ticking noise? (on video) whats the noise?
    Wierd engine noise Discovery V8 - YouTube
    Please ignore the random footage, I was trying to increase the sound sensitivity.
    After turning the engine off, the car then wouldnt start, It would turn over but not start? I dont think the plugs were firing? after 10 minutes and me holding the accelerator down it finally started and then drove home like nothing went wrong?
    It has been suggested to me that it could be a problem with the ignition module, or coil?
    Im sorry I have no knowledge of these engines or there electrical systems.
    I have a new ignition module and I picked up an old distributor of a wreck the other day so I have all that.
    If someone could walk me through what could be going wrong it would be great. This is really starting to become a problem as I sometimes travel away from town.
    Sep 2012
    Tuncurry
    Check and clean connections to ignition module, maf, tps, and o2's if you have them. as to the ticking sounds, have you changed your fuel filter? get ur fuel system pressure tested, might not have any pressure (like the pumps buggered)
    Sep 2012
    Tuncurry
    oh and exhaust manifolds can leak, (and suck in clean air) tripping off the o2's, when they leak they tick, you will notice it ticks way louder under throttle, in my experience.
    Crafers West South Australia
    Ignition modules can do strange things on these things, as can dirty or loose connections around the ignition coil. I lose count of the number of modules I have upgraded, must be nearing 100 by now. The positive and negative coil connections are often loose and can be corrected by carefully squashing the female connectors until they get a good grip on the mating part. Sometimes I cut off the OEM positive wire terminal and crimp on a new (fully insulated) one after cutting the wire back to clean copper. Did one just yesterday to a forum members RRC.
    Bosch ignition upgrade thread here:
    Lucas ignition amplifier replacement by Bosch 024
    Oct 2012
    Ingleburn Sydney NSW
    lol, I just watched the video and have no idea re the weird noise but I just loved the the end.
    Bonnet slams shut, video ends.
    Where were the expletives, did you head straight to the fridge for a coldie or head for the sledge hammer .
    Come on fess up
    Jan 2013
    NSW
    oh dont worry the expletives were there, this damn discovery has been the source of more expletives then any car I have ever owned!
    Did you replace the ignition module as was suggested early in the discussion on this vehicle??
    Jan 2013
    NSW
    Hi Garry Im yet to do that, as I had to wait nearly 3 weeks for repco to get the right one in.
    Im just more worried about what the noise is?>
    I think (well I guess hopefully) your engine problems will be fixed when you get the module - not sure why you ordered through Repco though as they are not what they are used to be - as you are in Armidale I would have rung All Four x4 in Kotara and they would have one to you the next day or so.
    As to the noise - not sure - my TDV6 make similar noises but it is supposed to do it - various solenoids.
    My two D1 V8s never made that noise - it sounds like electrical spark to me - possibly in the alternator but could be HT spark - try running you car in a dark garage at night with no lights on and see if you can see any blue sparks anywhere. That is about all I can offer on the noise issue.
    Jan 2013
    NSW
    Thanks Garry,
    I will never use repco again, it was all overnight deliveries with about 12 mistakes! but I had some fault there to.
    The problem with this problem is that there is so long between it happening. I cant reproduce it in the shed cause it just wont happen! same as for taking it to a mechanic they would have to drive it for a week to experience the problem.
    Lets hope this will fix it.
