Results 1 to 8 of 8
Thread: has anyone attempted to make their own cooler line pipes with Hose clamps?
    Aug 2011
    Melb
    As another one of my Rovers is leaking oil for everywhere possible (and some impossible places) my brain just wonders if anyone has tried to remake these oil cooler lines with Hose clamps instead of the Crimps used? I imagine the initial cost would be expensive but surely that would be outweighed by ease of serviceablity later on or will the oil pressures be too high for the Hose clamps to cope?
    St Helena,Melbourne
    4.28 MB
    Not replaced but i did use a couple of brass fittings and clamps to repair my auto cooler lines where they rubbed thru, the pipes dont often fail and usually the hose that splits or leaks from the crimps.
    You can take the metal pipes to pirtek and others to have screw on hose fittings added.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    you might do it as a patch job to get you home but thats it.
    99.87 MB
    Any mods that I'd had with push on and hose clamps hasnt worked. Multi barbed pressure Pirtek type fittings are the way to go.
    Slunnie
    redrovertdi Guest
    My transmission cooler pipes are all home made[cut pipes at gearbox end and slid transmission cooler hose over and clamped with pressure hose clamps from pirtek and not with jubilee style clamps. worked for me for past 2 1/2 years, I have a heat sink cooler mounted on my bullbar and a radiator style cooler between my front intercooler and radiator with twin thermo fans behind.
    Aug 2011
    Melb
    Talking
    Quote Originally Posted by redrovertdi View Post
    have you got any pics of you home style pipe job on the forum?
    redrovertdi Guest
    really hard to get a photo of
    Aug 2011
    Melb
    looks good!
