Thread: t seal 300tdi defender
    Dec 2010
    cairns
    hi all ive been doing a bit of work on the old girl defender not missus
    its a 1998 110 300tdi ive had a oil leak that I believe to be the t seal
    between the sump and the bell housing been leaking for the last 5 years
    was not to concerned but I think its seeping through the bell housing as oil is now coming out of the drain hole in the bell housing so think I need to fix it
    its not the sump or rear main, only need to top it up every 1200ks or so
    wondering can this be done with the gearbox in. any feed back appreciated
    cheers.
    Jan 2010
    Oct 2006
    canberra
    If its coming out of the wadding plug my money's on the rear main.
    Dec 2010
    cairns
    t seal
    don't think so got silicon where sump meets bell housing with out silicon
    it pumps out, had rear main done 60,000ks ago when clutch was done
    maybe they are both gone
    Dec 2010
    South Scotland
    If its out like the 2.25 setup then it's gearbox off or engine out.
    Byford, WA
    Hi Mudder 110,
    Sorry my friend I would say that one or the other is coming out. Knowing what I know now taking the engine out will be easier than trying to drag the gearbox out and then struggling underneath the vehicle replacing the seals, which ever one or if both have gone.
    I would say taking te engine out is by far the easier option, when it is out you can check everything else and replace a few of the other susceptible parts / gaskets. The 300 tdi motor in the defender has plenty of room for access. Might want to do the timing belt while you are at it, if you are planning that get the crankshaft bolt undone before you take the engine out and make the proper jig to hold the pulley.
    If it is just a quick out and back in still think taking the engine out is by far the easiest option. The gearbox is heavy and awkward to balance, considerably easier if you have access to a hoist.
    Dec 2010
    cairns
    cheers marty engine out is the go got a mate with all the gear so looks like ill be up for the refreshments thanks again
