Results 1 to 6 of 6
Thread: Clarke Mig 151te Parts in Oz?
    Kallangur, Brisbane
    Brought my Clarke Mig 151te welder with me when I emigrated from the UK. Has anyone any idea where Clarke spares can be purchased either in Oz or on line in the UK from someone who ships to Oz? I need to replace the wire liner with a metal one hopefully & I also need more contact tips.
    Rory
    + 2016 D4 TDV6
    May 2008
    Horsley Park, Sydney
    You can do worse than asking Silverwater Welding Supplies. Ph: 02 9748 1868 as they are one of the largest welding suppliers in Sydney. Not sure if they are Clarke agents.
    If they don't carry what you need, they usually get it in.
    Erich
    2stroke Guest
    Maybe take the liner and a tip to a local welding supply place, comsumables should be easy to match.
    Kallangur, Brisbane
    Thanks Guys
    + 2016 D4 TDV6
    Oct 2003
    Godwin Beach Qld
    I would suggest that you try "Trade Tools Direct", there is one at Caboolture and also one at Strathpine from memory.
    Williams West Aust
    Does it have Binzel(brand name) on the handpiece at all???
    If so you are in luck,they are used on many common Mig welders and parts should be available at any good welding supply shop.
    Mine has a Binzel MB24,which Ive seen on 4 or 5 other migs of different parentage.
    GOODLUCK
    Andrew
    DISCOVERY IS TO BE DISOWNED
    Snow White MY14 TDV6 D4
