Results 1 to 10 of 21
Thread: Timing belt kits
    Oct 2006
    canberra
    Timing belt kits
    Mines due and I'm wondering what kits you blokes are useing? I gather genuine is dear as poison. And what kind of mileage are you changeing your belts? Mines done 70k there abouts since the last one
    Judo's Avatar
    Judo is offline ChatterBox Silver Subscriber
    Feb 2012
    Parkdale, Melbourne
    300TDI?
    I bought a kit from the UK. Dayco belt + new gears - IIRC a idler gear and crank gear with edge lip.
    - Justin
    '95 Disco 300TDI - sold
    '86 County 110 Isuzu
    2006 Range Rover Vogue td6
    Oct 2006
    canberra
    Yup 300tdi what was the damage?
    Judo's Avatar
    Feb 2012
    Parkdale, Melbourne
    I think it was about $120.
    - Justin
    schuy1 Guest
    I always use Dayco belts, dont always change pulleys or gears. Did that at 180k. am replacing idlers and tensioners at this 1 320k.Change at or around the 60-70k mark. Let the first go to 100 on L/R advice and it let go! That was just b4 the changed service interval to 60k! Some pics of a belt at 70k compared to a new 1.
    Cheers Scott
    I just ring MR automotive and say
    TDI300. timing belt kit please, deliver to XXX/yyy credit card number is.
    never hada problem yet.
    Oct 2006
    canberra
    Think that's the ticket
    NSW far north coast
    Karcraft, they supply the Bearmach kit which has all the right bits including the one piece crank pulley
    Jul 2011
    Yarrawonga, Vic
    Just to throw a spanner in the works, (read.. I need to get off the damn internet)
    The thing that I considered most when buying another LandRover ( after a catastrophic 1HDT timing belt failure ) was 'does it have a timing belt ?'.
    which is why I chose a Td5
    so anyone here tried a Zeuss Timing gear kit on a Tdi. If I had Tdi it would be a priority for me & if I'd known they were available I might have considered Tdi instead of Td5 ???
    Zeus Timing Gears-50,000 km Review.
    flame away, I know in reality they dont give much trouble, but once burned ...
    NSW far north coast
    Don, have you ever read up on how much trouble the Zeus kits have given over the years ?
    Plus the weight apparently is something else too.
    The Tdi's are pretty good these days.
