VS is 4 wheel disc.not known for positive pedal with cold pads.
some utes have rear load pressure limiter--lever connected to diff to adjust max rear pressure.
for a normal ute 1085-1086 pads
in the dealer we used a shandy pads for the front--different compound inner outer,one suits colder application.VN VP wouldn't stop when cold and last VR=VS I drove was much the same.the disc is different,but they have a different booster setup.
work been buying stealth pads-it has a soft backing for noise reduction that allows the pad to twist in the holder..they also been chewing out the inner pads and have a dreadfull feel.rego brake test is ok when new pads.
all hard km!
