Results 1 to 10 of 11
Thread: 8 Spd Auto for the Amarok?
    Oct 2010
    Caloundra
    Alright, I tend to be about 20 years behind in automotive trends, BUT
    Saw an ad last night for the VW Amarok, which has an 8 speed auto. Not quite sure what the advantage of an 8 speed over a 4 or 5 speed auto is, but I'm assuming that as the number of gears increases, then either the size of the gears must get smaller, or the auto box itself must get bigger and heavier (bringing its own problems).
    At what point does a CVT gearbox start giving an advantage over having lots of different gear ratios? Seems like a pretty simple solution to me, not sure why they're not more common.
    South Sydney
    Towing...
    Jun 2010
    Eleebana 2282
    Its similar to having a Fairey overdrive or a high/low range transfer case, instantly doubles the number of gears.
    Sussex Inlet. N.S.W.
    My mate has one for work. Loaded weight is 2.8T. It is a 2l motor with twin turbos and he gets 10l/100k. It has an auto box and he loves it.
    Jim VK2MAD
    '17 Isuzu D-Max
    Mar 2007
    South Arm, Tasmania
    Better not look too closely at the current model Disco then. or the Jeep.
    The Amorok is far from being the only vehicle out there with an 8 speed auto.
    Cheers .........
    BMKAL
    Oct 2010
    Caloundra
    Don't worry, I'll be looking a very close look at the current Disco 4s.
    In about 15 years time when I can afford to replace the Disco 2 I'm driving now.
    Adelaide - Torrens Park
    Quote Originally Posted by Pinelli View Post
    At what point does a CVT gearbox start giving an advantage over having lots of different gear ratios?.
    At engine sizes of two litres and below (for low torque petrol engines). CVT transmissions aren't very strong.
    Garwood Guest
    I've got a new MY13 Disco 4 HSE which has an 8 speed auto....it's incredible. I'm averaging about 9.8l per 100ks...
    The combination of this gearbox with the 3.0l diesel is magic. So smooth, effortless acceleration.
    Kiwiland
    Other way around. Lots of gears means no need for cvt.
    Jun 2008
    The new Gold Coast, after ocean rises,Queensland
    there is no transfer case....the lower ratios are significantly low enough. I drove one last week. incredibly smooth, seamless power delivery. If you drive conservatively it skips gears, if you give it some it uses them all and propels the veedub along very briskly indeed.....would I buy one?....yes! what a nice vehicle to drive....it makes all the other 4x4 utes seem exactly like the trucks they are.....I have driven "them" all recently.
