Results 1 to 10 of 24
Thread: Bolt and screws for SII
    Jul 2013
    ravenswood, Western Australia
    Hi all,
    Does any one know if there is a list of bolt/screw sizes used on the SII?
    If not, would it be a good idea to start a list where everyone can add bolt/screws sizes and where they go as a reference?
    as i am starting to rebuild mine i could make a start on such a list, also i have a question about a certain bolt size
    I have just ordered a Mixture Warning Light Switch from Four Wheel drives (Land Rover Parts and Accessories) part #PL144 on page 51 out of there catalogue #32,
    Does any one know what size bolts go in the three holes (mine have become lost in transit between moving houses) ?
    cheers for your time and help everyone
    Jul 2013
    i have just found out the switch is also called an Otter switch as this is the name on it
    Jul 2013
    or if you type - choke warning light switch series 2 land rover - in to google it comes up with a picture of it ( the triangle one)
    cheers again and sorry if i am being a complete noob
    Nov 2011
    Can you post a picture of what you're talking about - the link just goes to a "New website coming" page
    I think the problem with having a nuts and bolts list is that so many different sizes and standards were used over the years
    Mine a 69 late 2a - and generally has UNF, with BA on the instruments and some of the finer bolts, but there's some Whitworth kicking around on the drivechain. Theres quite a bit of metric as bolts have been changed over the years as well.
    I bought a bucket of UNF bolts from - Nuts and Bolts - Industrial Size Assortment Packs of Hi-Tensile Nuts & Bolts which has covered most things I've needed, but some things I've just taken in to the local bolt factors and got them to match the threads
    Nov 2011
    Like this?
    if so I'd suspect BA threading - but I'm not sure of the size, sorry.
    I'll guess at 0, 1 or 2
    Jul 2013
    That's the ones Ozdunc,
    I thought that would be a problem to about having different bolts as times changed at the factory, I was more thinking a rough list that might say shock absorbers then their length and what thread they are. Nothing to technical just maybe something for people to get a good start at where to look.
    Sorry about link, wasn't actually meant to be a link more to let you know where I had ordered the part
    East-South-East Girt-By-Sea
    1.20 MB
    Classic Fasteners in Welland South Oz CONTACT US is a good place to start for imperial bolts and nuts (Including BA). Important for the SII and S1 because most fasteners are either BA or BSF.
    Jul 2009
    S.E.Qld
    They are 2 B.A. x 3/8". The same thread size as the ones used to fix the speedo cable at the gearbox end, however those are only 1/4" long. .W.
    Narre Warren South
    Probably best to buy a thread pitch gauge, that way you can check the threads and determine whether UNF or BSF (or W or UNC etc.)
    https://www.machineryhouse.com.au/Q610
    Most important where they thread into something (engine, axle etc.) if its a just bolt & nut then UNF is easily sourced (might upset the purists though.....).
    Most bolt places will source BSF but they may want you to buy in bulk, they might struggle with HT bolts.
    Thread pitches are here British Tools & Fasteners - BSF Thread Profile
    Not sure about the freight costs but I used to buy from these guys when I lived in the UK Namrick - The Nut & Bolt Store
    Colin
    '65 Series IIa Dormobile
    '70 SIIa GS
    '76 SIII 88" (Isuzu C240)
    '81 SIII FFR
    '95 Defender Tanami
    Motorcycles :-
    Jul 2013
    Just tried the speedo cable bolt like you said B.S.F Nut and its a perfect fit, just a little short but now i know the bolt size, also noticed i am missing a bolt where the speedo connects to the gear box so it was a good find.
