its all good.
if the mating surfaces of the housing and the cover plate are peftectly matched you dont even need the sealing goop.
When I redo any oil pump I completely pack the thing petroleum jelly ensure the mating faces are completely clean and then put a smear of hylomar #3 on the pump housing side of the joint and loctite 243 on the threads of the retaining bolts.
The fine polishing/wear is normal but a hi res well lit macro photo of it will help us give you a go/no go for use but I'm pretty sure the permissable tolerance for wear is in the RAVE, The values havent changed in years so pretty much any of the specs for the oil pump from any of the engine will keep you running.
