Thread: Oil pump
    Mar 2012
    Epping, Vic.
    Oil pump
    Hey guys!
    Early petrol disco oil pumps? Know to wear out around 220k? I havent checked actual pressure yet but on my recoed 3.5, after being quiet on startup, lifters start making a racket after getting warm and back on idle.
    Yes, they are new as with cam.
    Forty minutes closer to the hills in a house the bank is kind enough to let me live in
    Check oil pressure before investigating anything else. Oil pressure would have to be perilously low when hot for your lifters to be the source of the noise when warm. Normally something else would be the culprit for noise when warm or hot.
    What was done for the reco?
    Be aware that the oil pump's delivery at idle depends on correct clearances between the gears, the timing cover and the pump cover - these are influenced by gasket thickness and not all gaskets are the same.
    Crafers West South Australia
    If yer lifters rattle due to low oil pressure just run oil a little thicker, say a 20W50 or 20W60 Penrite. Works for me.
    Oct 2007
    I had a similar issue, couldn't work out why they were getting noisy till one day at idle I saw the oil light flicker, quickly checked my mechanical gauge and pressure started to drop.
    I killed the engine, towed it home and pulled sump off to find the pickup was hanging by one bolt.
    Fixed that up and no more noises and luckily no knocks.
    Rez
    Mar 2012
    Epping, Vic.
    Well, no change with 20w50 and new filter.
    Reco was big ends, mains, pistons, rings, cam/lifters(and bearings),timing chain, valves. It SHOULD be really good but am dissappointed.
    Did you check all the new crank to bearing clearances before sealing it up?
    Worn rocker gear can also return funny oil pressure readings if disturbed during a rebuild. That aspect can be checked with the engine in still in the car but the rockers off. If you drive the oil pump and find it bleeding out excessively somewhere on either bank it might be a simple fix.
    St Helena,Melbourne
    4.28 MB
    How did you prime the oil pump ?
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    Mar 2012
    Epping, Vic.
    Packed it with vas
    Quote Originally Posted by xstriple View Post
    Packed it with vas
    And the clearances were... ?
    Mar 2012
    Epping, Vic.
    Does anyone know at what minimal pressure the oil light comes on?
