11th August 2013, 05:18 PM
Diff Breather washers
Hi,
Well I decided to clean the diff breathers today, when I took the rear off I noticed that there was 1 copper washer missing, prob the reason my diff had water in it when I changed the oil a week ago, question is where can I get some of these from, or is there a bunnings substitute.
Kevin
11th August 2013, 06:32 PM
I've seen cooper washers on those champion nut/bolt/washer displays that are in supercheap etc
11th August 2013, 08:55 PM
Try a brake shop if you have no luck there jut a standard brake banjo washer
