Thread: reversing camera
    Jan 2009
    hervey bay
    reversing camera
    I have bought myself a reversing camera and am trying to work out which wires to hook into 2004 disco 2a according to rave the reverse light should be a green/brown from what I can figure out but where to I put the black wire ? [ the wirering diagrams don't make a lot of sence to me ]and where is the best place to get power for the screen at the front
    thanks
    Aug 2008
    West Pennant Hills
    Can't help you with the rear light wires (I've got mine so I can turn on any time so when loaded can see what's behind). However, in the fuse box above drivers feet there is at least one spare spade connector which is free and which is connected to the ignition. Just check with multimeter. Alternatively, you can buy a spade fuse "double adapter" which replaces a spade fuse with a holder for a fuse and a new power source. See for example:
    BAINTECH AUTO BLADE FUSE HOLDER - Double Adaptor | Battery Business.
    Feb 2011
    Denmark Western Australia
    Thanks for that tip never seen them before, but will looking now...Gary
    Avoca Beach
    The fuses are live all the time which you don't want.
    Someone posted here a while ago, that even if sunroofs are not fitted , there are wires for them sitting at the top of the screen.
    Sure enough I dug around after taking of the plastic thingo, and found a wire that is live on accessory. ( and an earth wire)
    If you have a sunroof , just tap off the power wire.
    I have fitted my screen just behind the rear view mirror and that is a great place for it IMHO. A 4Inch screen is best.
    I bought a $50 RF camera one from ebay and it works well . The receiver can just sit on the shelf next to the rear view mirror.
    Regards Philip A
    Jan 2009
    hervey bay
    I have been waiting for my headlining to be done and was going to run all the wires when its out but has been put off for a couple of weeks
    thanks for your input fellas
