16th August 2013, 11:02 PM
Rocker cover gasket sealer recommendations
I replaced my wiring loom under the rocker cover a few months ago and also the gasket with new original land rover parts.
The rocker cover is now leaking near the back.
I'm planning to take it off and use a sealant as I never used one when I put it on.
What sealant do people recommended for this?
I've heard Loctite make a good sealant but there are so many versions to chose from.
17th August 2013, 03:22 AM
You want a sensor safe one. In the loctite range it is the black one. It will b clearly marked on the packaging
17th August 2013, 07:27 AM
The LR part for this task is STC50550 which is a 95g of what is supposedly Loctite 5900. It should be around $25-30 a tube. Some of the UK sellers list Loctite 586 as the OEM alternative. I think this is the same as Loctite Black Maxx?
Paul
17th August 2013, 10:44 PM
#4
Thanks guys. I'll grab some black maxx.
This may be a dumb question but what would you clean the gasket and two surfaces with before using the black maxx?
Metho or is it bad for rubber gaskets?
18th August 2013, 06:25 PM
#5
Went into Repco today and they had grey maxx and gold maxx but no black maxx.
The grey looked like it would do the job but I wasn't sure and so left without buying anything.
What's the difference in grey and black?
18th August 2013, 10:35 PM
#6
Black is darker? But only until they invent something darker!
19th August 2013, 01:21 PM
#7
Thanks Didge. I feel enlightened. ;-)
