Results 1 to 10 of 12
Thread: wood gas converter
    Aug 2008
    latrobe valley victoria
    wood gas converter
    anyone seen, heard or know of series ones run on wood gas converters in the past{pre ww2 ww2 and after?} also any pics?
    regards mark
    2002 defender 110 , 1955 86 inch
    Narre Warren South
    Quote Originally Posted by mfc View Post
    regards mark
    Series I's weren't around pre WW2.
    I remember seeing pictures of cars in the UK that had massive bags of gas on the roof and towing gas generators during wartime rationing. OH&S might restrict some of the contraptions nowadays.
    Some info here Low-tech Magazine: Wood gas vehicles: firewood in the fuel tank
    I can just imagine turning up for a roadworthy with a wood gas generator fitted. VicRoads have enough trouble with the straightforward stuff.....
    Colin
    '65 Series IIa Dormobile
    '70 SIIa GS
    '76 SIII 88" (Isuzu C240)
    '81 SIII FFR
    '95 Defender Tanami
    Motorcycles :-
    Davehoos Guest
    Brazil[south America] had lots of these until alcohol become the norm.
    sort of why petrol powered trucks rulled up to the 80's.
    Narrogin WA
    Thanks for posting that link Colin - what a balanced and informative article!
    About 5 years ago I tried to research the subject but my choice of "charcoal burner" was a poor one and yielded meagre results. I did find; however; a blog by an old couple who were touring Australia in a Kombi with wood-burner behind them in a trailer.
    At the time I thought it would be cool to turn up to a motor show in the S1, with a trailer attached and running on charcoal-gas.
    In any case, to me a wood-fired car has distinct advantages for some applications such as: a medium to heavy car, capable of towing heavy loads; no hurry to get somewhere; an abundance of free or cheap firewood; a thick-skin to deflect the ridicule of passing idiots; zero tax on the fuel, if you grow it yourself. It seems to me that Australia offers most of these things already.
    I still think that in the oil-starved future, more of us will look keenly at the idea. A Megajolt programmable ignition map would be ideal for getting the spark in early. Petrol fired tractors, which are a bit of a rarity nowadays, would probably respond well to wood-firing and you could grow your own fuel like I do
    Cheers Charlie
    Aug 2008
    ;petrol rationing went on long after ww2 food to, more asking for pictures of any local cars or engines fitted with converters . Ive seen pics of the balloon devices as well im thinking that the coal gas ones were run on charcol{you can make that youreself as well.
    .. Im with you chazza ,in the wood department, i could drive to canbera with an axe lol ..id be thinking in these days thered be room for minimisation as well ,and even if not the'd fit easily in the tray of a swb let alone a lwb, might have to get a series 2 to try it on.{might need a wood gas powered chainsaw as well lol}
    The Gengas Page
    Fluidyne Gasification - Archive - Since 1976
    http://www.hotel.ymex.net/~s-20222/gengas/kg_eng.html
    an interesting mental exercise at the very least :}
    regards mark
    Jan 2008
    Nowra NSW
    there are a lot of problems with gas producers.
    You need the right sort of wood in the correct size cubes, or access to charcoal
    Filters and water coolers are needed.
    Your motor will need regular decokes as the tar and ash deposits quickly sludge up your valves and piston rings.
    wood gas has not much bang to it and you will get a 40 to 50 percent reduction in engine power.
    You have to do regular stops to stoke/ shake the burner and clean the filter.
    You have to get it lit , warmed up and burning correctly before you can go anywhere.
    people were very happy to get rid of gas producers after petrol rationing.
    Narre Warren South
    A few more links :-
    Rationing. Petrol rationing in WW2 « Crude Oil Peak
    Land Rover on wood gas. GMC, Workshop
    More on wood gas Wood Gas conversion
    Colin
    '70 SIIa GS
    '81 SIII FFR
    '95 Defender Tanami
    Motorcycles :-
    Jul 2010
    I have seen them
    When I was a kid in Brisbane in the 60's I used to see a 37 Chev getting around with a wood burner on the back. It kept up in the traffic ok . My Dad told me that there were quite a few set up during the war.
    Mike
    Jan 2008
    Nowra NSW
    everything to need to know about setting up a 101 landrover to wood gas.
    101 club • Login
    WA
    I doubt a SWB would have enough room for all the gear...
    [ame=http://www.youtube.com/watch?v=esqma3ZI4CE]Wood gas car in Helsinki 2012 - YouTube[/ame]
    Plus with the 50% power drop you would only be able to drive in low range...
