Results 1 to 10 of 17
Thread: Buying Ex Military!! Help me!
    Nov 2011
    North side Brisbane
    Hey guys,
    After selling my defender 6 months ago and regretting it every single day since then. I am contemplating buying an Ex military LR at auction on grays. Solely to be used as a camping/fishing and bush bash truck. Can anyone tell me about them?
    I have noticed they are 4 spd, Is it possible on the off chance that you find a LR country 5 spd and slip it in for more comfort? Or is there an alternative?
    I am going to try and have a look tomorrow, what should I look for?
    Thank you!
    Nov 2011
    North side Brisbane
    Oh and one more thing! Are they hard to get registered in QLD?
    Feb 2005
    there are a few threads floating around already.........and this website could be helpful
    buymilitaryvehicles.com
    Oct 2007
    wetherill park
    Qland rego is no problem have a look through this thread its long but lots if info
    http://www.aulro.com/afvb/military-v...-disposal.html
    East-South-East Girt-By-Sea
    1.20 MB
    They are rather high in the gearing so highway speed is not a problem and the 4 speed box is almost bullet proof, which you can't say about the land Rover 5 speed alternatives.
    If you can get a Isuzu 4BD1 bellhousing on an LT85 it gives you the fifth gear, but by far the best option is "the Grubb's" Isuzu 5 speed gearbox conversion. You are looking at several thousand dollars to get all the bits for the conversion.
    Diana
    Auxfire Guest
    Hey Romey,
    Registration in QLD is not a problem now as both the hard tops & soft tops have been added to the Dept of transport & main roads vehicle list. They do not require inspection on site either as long as your roadworthy is current.
    Keep in mind when buying though that you will only get the vehicle registered for seating which is both forward facing & has compliant seatbelts. In most of the soft tops this is 2 seats only with the 5 door lightweight personnels being registered for 5 seats. ( side facing rear seats are considered non compliant.)
    If you do intend to buy one the best advice I can give you is to research, research, research!
    Check the log books & inspect them if you can.
    Most importantly learn how the GraysOnline auction system works, it's not EBay, you don't win instantly if there has been bidding activity in the 10 mins prior to end of auction.
    So find the one you want, bid on it with just under 10 mins to go & you might just pick it up for a song. Whatever you do don't get drawn into a bidding war when it enters the 'going, going, gone' frenzy
    Nov 2011
    North side Brisbane
    I was able to sneak in a quick look at a few today (was not able to take it for a spin around the lot ). Found one that I like, the log book seemed i good order, plenty of work done on it recently belts, seals etc. The engine fired up first time (was a bit noisy/rough)! had the usual dints and scratched and all of the light worked.
    My only concern was the front diff looked wet but I couldn't figure out what it was. I think im going to make a few bids on it tomorrow and see how I go!
    Thanks for all of the info!
    Near Seven Hills, Sydney
    You were lucky to be able to hear it running, at Minto there are a lot of signs saying they must not be started.
    Oct 2008
    Heart in the Deep Nth of FNQ,Body in the Deep Nth of Brisneyland
    G'Day Romey, welcome to the Forum.
    Stick with the 4 speed, the 3.9 litre Isuzu has the torque to pull you along sufficiently for an old 4wd. Remember, just because it has a soft top doesn't make it a sports car
    The gears are stronger and you can do some easy mods to get highway 'legs'.
    You may want to change tyres anyway. if you go up to a 33 inch tyre you will pick up the higher speed enabling you to keep up with highway traffic, just buy some earmuffs.
    No, seriously!
    Not a lot of sound deadening in thin wall aluminium and canvas. quite the opposite!
    Low down performance won't suffer thanks to the previously mentioned Torque mountain of the Isuzu donk.
    Keep watch on the Buyers Guide site. I have the nose to the grindstone the next couple of weeks to get the Guide finished and checklists available.
    I hope this helps.
    Cheers, BDave.
    Replace "You are...!", with "Are you...?"
    Army Land Rover Buyers Guide.
    Reunited with RFSV 51 680, 'Sleazy'!!
    '00 VeryDisco TD5 Auto,
    Nanocom Evo for D2 TD5 and Puma
    Gone:RFSV, 51-699, Carryall 48-358.
    Apr 2012
    Quote Originally Posted by isuzutoo-eh View Post
    Yep they told me due to being indoors and regulations etc etc.
    For NSW below!
    Viewing for the Auction is on the 12th - 8am to 4pm at Minto
    Next auction sets run from the 10th through to the 16th.
    Prices start for non complete around, 2 grand and you could get a decentish Parentie for around 4 grand.
    They come with blue slips for NSW, super easy to rego!
    Ben
    Last edited by rb30gtr; 2nd October 2013 at 12:15 PM. Reason: Clarifying location - NSW - Sydney
