Results 1 to 10 of 13
Thread: High revs at idle
    May 2006
    High revs at idle
    My V8 Disco is revving too high. When i first start it with no throttle it revs at 2000rpm and then slowly drops to 1000rpm after 10- 20 sec.
    When i stop at lights and put it in neutral it is doing 1500rpm. Sometimes it will drop back to 800rpm.
    It is an auto and it is much harder to stop as a result.
    What are the likely causes?
    Quote Originally Posted by vogue View Post
    First off I'd check for a binding throttle cable, ensuring that the butterfly in the throttle body is properly seated when foot is off throttle...
    Feb 2011
    Denmark Western Australia
    Hi, mines done the same , but only after I put the timing up to 10DEG, BTDC...Gary
    May 2006
    I do have the timing set to 10 btdc for the lpg.
    Also about to fit a new vacuum advance. Could that have something to do with it?
    Crafers West South Australia
    You can of course set the base idle lower. Insert a 3/16 allen key in the hole atop the throttle body and turn it inwards a turn or two. Failing that it may have something to do with the road speed input to the ECU being crook but I don't know anything exact about that.
    Feb 2011
    Let me know how it goes with the new vac advance please...I don't want to alter my base idle as when it does come down it would be to low...I basically learnt to live with it....only prob going down a steep hill in low ..if I need to blip the throttle it takes off ...
    Quote Originally Posted by Gary S11 View Post
    You do understand the vacuum advance doesn't get vacuum at closed throttle? It will make no effect to the idling speed.
    streaky Guest
    Sounds to me like the stepper motor needs cleaning.
    It's the large plastic bolt head thingy at the rear left of the plenum.
    Unclip the plug....unscrew the stepper motor and clean everything in sight with contact cleaner. Don't be tempted to mess around with the plunger spring...just extend it very carefully and clean the plunger seats with contact spray.
    Screw it back in hand tight plus a quarter turn (max).
    Then pull the EFi fuse for ten seconds to reset everything.
    May 2006
    Ok, i pulled out the stepper motor, it was black on the tip. I sprayed the tip and spring with contact cleaner (does it come apart?), put it back together and started. The revs still started high, 2000rpm but dropped back to normal within 5-7 secs.
    Any ideas?
    Feb 2011
    Thanks bee utey, I realised that but my probs not at idle, it's above 2000 rpm, the same as vogue, blip the throtle and it sits above 2000 and slowly drops to the correct base idle
