Results 1 to 4 of 4
Thread: Horn - Dead or Alive
    Jul 2013
    ravenswood, Western Australia
    Howdy all,
    i just pulled the top housing off my Horn because i could hear some thing inside like sand, and it was.
    Does anyone know how to test to see if the Horn still works?
    I have added a photo that shows something all over the insides
    Cheers for your time
    Jul 2012
    midwest W.A
    Hook it up to the battery
    Narre Warren South
    Quote Originally Posted by SII Josh View Post
    Howdy all,
    The stuff over the insides looks like melted or decomposing insulation.
    The horn is a simple device just a solenoid and a set of contacts.
    When you connect to a battery the solenoid moves & opens the contacts, the solenoid releases and the contacts close.......this repeats over & over again at high frequency
    Check the contacts open mechanically and look clean, if not pull some emery paper through the contacts to clean then holding them open pull some rag with some metho on through.
    Connect to a battery (get ready to disconnect quickly if that is melted insulation !) If it doesn't work there is an adjustment on the contacts, undo the locknut & adjust (be prepared for when the horn suddenly starts working !!).
    Best of luck.
    Colin
    '65 Series IIa Dormobile
    '70 SIIa GS
    '76 SIII 88" (Isuzu C240)
    '81 SIII FFR
    '95 Defender Tanami
    Motorcycles :-
    Jul 2013
    Well after all the great advice the Horn has been pronounced Dead.
    new one on order
