21st August 2013, 06:28 PM
97 disco brakes abs.
Hi I have a 97 auto disco tdi and I will be replacing the master cylinder and servo unit .I want to know if I can put both together then bolt it up as one unit or one part at a time,servo then mast/cy. I will also be replacing my rear discs as there worn bad and want to try some new ebc green stuff pads for a bit more grip.All my discs are solids .
Thanks in advance.
21st August 2013, 10:59 PM
Hi mate,
I separated mine because my gas system meant I just didn't have the room to wiggle everything around at once. RAVE said to do em separately as well.
You will need to reset the brake light switch and the cruise switch once its all back in.
