Results 1 to 10 of 16
Thread: Big Black Sphere thing in engine bay of D1
    Jan 2013
    Penrith
    Hi,
    Next to the power steering reservoir is a black ball a vacuum pipe goes from it to the Plenum and wire go to the ecu I presume, what does it actually do?, I was looking at the vacuum pipe from it and have found that someone before me has put a cable tie on it rather tightly in what looks liks an attempt to block it, any idea why this would be? And what effect it would have
    Crafers West South Australia
    Vacuum reserve for the cruise control I believe.
    Jan 2013
    Penrith
    Hmmmm.... I have early 93 D1 no cruise control..
    Feb 2012
    Parkdale, Melbourne
    Heater vent controls?
    Edit: Or heater core value? Something heater or air con related.
    - Justin
    '95 Disco 300TDI - sold
    '86 County 110 Isuzu
    2006 Range Rover Vogue td6
    Boony73 Guest
    I don't recall seeing one in my V8's do you have a photo? Some one may have retrofitted one for an aftermarket cruise at some stage or to fix a vaccum problem elsewhere.
    Jan 2013
    Penrith
    Looks like this
    May 2013
    Adelaide
    Ballcock for on board toilet??
    Jan 2013
    Penrith
    Quote Originally Posted by Petetheprinta View Post
    Pitbull Guest
    Looks like the heater control vacumn ball which is fitted to vr vs commodores. Does it have GM or the holden logo on it?
    Jul 2011
    Yarrawonga, Vic
    do you have maxi-drive difflock?, if so that would be the vacuum tank.
