Page 1 of 6 123 ... LastLast
Results 1 to 10 of 54
Thread: Diggers Stickers 2.0 (gathering numbers)
    This is the initial interest thread for the second run of diggers stickers...
    them.
    It'll be 6-8 weeks minimum before I start any real progress into doing the run (If I get enough interest)
    The anticipated cost is
    $2.75 per sticker
    $3.50 for postage
    this will work in about the same way as the surplus sell of run one was done.
    If you wish to order stickers simply write out
    There are currently Y stickers
    I would like to order X stickers.
    you need to order Y+x stickers required
    the Y for the beginning of your post comes from the last line of the post prior to yours.
    DO NOT edit your posts if you have hit send and then later want more just add another post
    DO edit your posts IF you hist send and someone else has posted between you starting typing and hitting send. Fix the mathys bit and save the changes.
    If you decide you dont want the stickers just send me a PM when I put the cut off point into this post and ask for people who want to opt out to opt out.
    I suggest putting a track on this thread so you dont miss the cut off, there will be a 2 week period after the cut off in which to provide payment and postage details. The run will go ahead after the cut off for payments date.
    Once again I will pick up the cost of any over-run production and will then run a surplus run post. any left over will be turned over to INC for resale in the shop.(or whatever else he wants to do with them)
    There are currently 0 Stickers requried
    Mar 2009
    Brisbane, Australia
    There are currently 0 stickers
    I would like to order 2 stickers.
    you need to order 2 stickers required
    Apr 2010
    There are currently 2 stickers
    you need to order 4 stickers required
    Jul 2010
    Lambs Valley - Hunter Valley, NSW
    There are currently 4 stickers
    you need to order 6 stickers required
    Many thanks,
    Lee
    Dec 2012
    Perth, WA
    There are currently 6 stickers
    you need to order 8 stickers required
    Happy Days
    Joel
    Aug 2010
    Sunbury, VIC
    There are currently 8 stickers.
    You need to order 10 stickers.
    Cheers - Gav.
    jplambs Guest
    There are currently 10 stickers.
    I would like to order 5 stickers.
    You need to order 15 stickers.
    Hay Point
    Hoping you still those 2 for me Dave. (the ones you forgot to give me when you where up here in January)
    Cheers......Brian
    1985 110 V8 County
    Jun 2008
    The new Gold Coast, after ocean rises,Queensland
    there are currently 15 stickers
    you need to order17 stickers
    Dennis
    Adelaide SA
    So, did the second run of Digger Stickers ever go ahead?
    I am trying to prep the car, ready for Melrose, and can't complete the set-up without it...
