                                                30th August 2013, 09:13 AM
			help to replace diff gaket
					Morning all,
 the front and rear diffs sprung a leak around the diff housings so i pulled the rear apart no problems and replaced the gasket.
 I have no idea how to remove the housing on the front diff,
 Do i need to remove the swivel pinion to slid the axles enough to remove he housing?
 cheers for the help every one
                                                30th August 2013, 09:26 AM
					Hi Josh,
 Yes, for the front you need to either remove the hubs at the flange between swivel and axle tube, or remove all the hub internals.
                                                2nd September 2013, 06:25 PM
					split the hubs from the flange between the swivel and axle tube like Mark suggested and hey presto, housing removed new gasket on and housing refitted in 2 hours with the help of my brother.
 Even managed to get the springs painted in KBS chassis black along with some other suspension bits and pieces
