Terrafirma make +5 shocks got them in my defender happy with them and good price too
Hi Guys,
Have 4" springs but need appropriate shocks however the most ive seen are 2 inch lifted shocks.
I remember seeing a disco in a mag using i think patrol shocks but not sure .. Any advice would be fantastic.
Thanks guys
Are you just replacing the stock springs with the +4in? And are you doing it yourself? If so my understanding is you will need to change your front suspension bushes, probably a 3 degree castor correction, or it will be a pig to handle, and should oversteer quite severely. If you have a diesel with a rubber donut on your rear propshaft will need to have a rangie or V8 uni-joint conversion or it will destroy itself. You will need to buy a set of extended braided brake lines. (Linn Rover here in WA sell them for just over $100 for +150mm from memory, the quality ones with the free nuts on the end.) And possibly one or two other things I have no idea about!You can buy lowered shock mounts to cater for higher springs, used with +2in shocks. I have just over +2in spring lift and I have noticeable oversteer and my donut is already half chewed out. I'll change the brake lines one of these days to be safe as well. Just a few thoughts.
Lane
Cheers guys !
Lane, i am doing it myself and have good mechanical experience i just not sure where to go for the shocks. Brake lines and accessories sorted, just shockers far to short
Pommy, would you have a link to those shocks mate ?
90 110 130 D1 RRC Terrafirma 5 Travel Shock Absorber - TF122LT
Not sure if that worked never done that before not very good with computers .
4" springs is overkill, 2" spring and 2" body is a better combo.
You will most likely need cranked and extended radius and trailing arms, castor correction, longer shocks (you already know), lengthened brake lines, rear uni conversion, double cardan/uni in the front.
Slotted swivels to counter act the castor correction etc.............
2004 Jayco Freedom tin tent
1998 Triumph Daytona T595
1974 VW Kombi bus
1958 Holden FC special sedan
No worries mate, Glad you know what you are doing.And I'm sure a proper +4in spring lift installation is better than a combo as described, Certainly far better in case of an accident anyway. Having said that I do have a +2in body lift in the shed!
Lane
Hi mate,
I have a 2" body lift and 2" springs at the moment however when i hit a sizable bump the 35" tyres at times hit the guards which im trying to avoid. I could go without the 4" springs at a push however i have them now and the extra 2" would definitely not go astray. I think your right about the radius bars as there is a 5" lift kit from the UK i found and it has the radius arms and a longer prop shaft.
Do you have flares?
extended bumpstops / bumpstop droppers also a consideration?
if your dead set on the 4" lift, i think you can do a gq / 80 series combo with pin/eye adaptors and come out ok, or just go the +5's. as mentioned, you will need more then just big springs and shocks.
just watch out too, 4" susp and 2" b/l is gonna be fairly top heavy in a disco. not trying to talk you out of it, just things to consider.
1986 Range Rover Hiline
2004 D2 TD5
