Results 1 to 10 of 11
Thread: Strange connection on Thor intake Plenum
    Feb 2013
    Gosford, NSW, Australia
    Hi,
    On the drivers side of my intake plenum are a couple of unconnected outlets, one of which has been blocked with a screw.
    One is the rubber tube with a screw in the end, and the other looks original and seems a bit like an airline connector !
    I was wondering what is missing here?
    Pic attached
    Steve
    Feb 2010
    Townsville, QLD
    The one with the screw in it is blanked off on every other Thor motor as well. I assume it may be a vacuum line for emission regs in one of the countries overseas.
    The other plastic/red/black one I have no idea what it does, again, it's on every Thor motor as well.
    Kingston, Tassie, OZ.
    in the usa, they have to endure a 'secondary air' system, this is likely the port that is blocked with a screw, see pic below;
    Rover V8 Secondary Air Injection
    the other air fitting one i am not sure of, as it is quite a large fitting.
    jc
    Avoca Beach
    I think it is for the evaporative emissions can which should be on the RH side Guard?
    Has it been taken off because of the gas injection?
    Regards Philip A
    Feb 2010
    Townsville, QLD
    It's not on my Bosch 4.6 Phillip, nor was it on my previous Bosch 4.6, both ports were unused. Neither ran/run LPG. I have not seen a Thor motor with these ports used!
    Keithy
    Crafers West South Australia
    D2 engines have a fitting in there.
    Don't all P38s run accumulator based ABS, i.e. no brake booster? One less hose to the plenum.
    Feb 2013
    Hi
    Bumping an old thread
    Does anyone know how that bigger connector is held in?
    I tried turning it gently and it turned but did not appear to screw out.
    If it has a thread I am thinking it's a perfect spot for the temperature sender for my electric fan setup
    Steve
    Jun 2011
    Wyalkatchem
    Push the hose in gently
    then push the red collar in and hold in while pulling on the hose.
    then the hose should come out.
    Works like a air fitting.
    On re reading you were probably trying to take the whole thing out, pass
    Sep 2012
    Perth Australia
    Hi Steve
    what type of temp sensor are you fitting for the fan, Im in the process of fitting a watchdog temp sensor that also has a relay that will switch on the fans earlier. Just need to find the right spot for the sensor.
    Feb 2013
    Hi
    I am using the Dakota Digital controller, which can take the readings from the factory sensor has dual fan control, setting of fan off and fan on temperatures plus run on after switch off.
    I will eventually use a dedicated sensor, a bit of a failsafe, most likely in the spot where that unused connector is.
    The watchdog I believe can be attached to any bolt around the head I would be looking at whichever looks easiest
    Steve
