I used the high beam dash light wire behind the speedo thingy. Four torque screws and one clip should get you there. From memory it is the orange and blue wire. Will have to look up the wiring diagram to check. It was very easy to run a cable to the relay under the bonnet from there. This is the place the Land Rover factory driving light installation instructions used.
