Results 1 to 3 of 3
Thread: Lights
    Feb 2010
    Lights
    My headlights come on as usual and then as if when they heat up they go on and off. On hi and low and on flash. They stay on longer on low than on hi and go off quickly on flash (hi/lo together)
    No blinkers but other gauges on same circuit working as usual. Blinkers were blowing fuses on ocassion in the past.
    hooked up new blinker/ dip switch unit and no change.
    Changed relay without any change.
    Any ideas?
    Where do I start looking?
    The S1 comes out of the shed and saves the day again.
    Jul 2009
    NSW
    The light switch. These are prone to burning out and causing all sorts of issues
    Probably the headlight switch.
