Results 1 to 10 of 12
Thread: I ordered one of these yesterday online
    olbod Guest
    A lightbar.
    Has anyone tried one of these ?
    Are they a good effective driving light at that lumen capacity ?
    Ta.
    Oct 2003
    Godwin Beach Qld
    I would suggest that you look at the LED lights thread by 101Ron as you might wish to cancel your order,as I was going to get a light bar but am having second thoughts.
    Gosnells
    Maybe all is not lost... the 'bar is an 8 degree spot.
    It matters not whether the LEDs are arranged in a line or around in a circle, the beams are narrow and pointed in the same direction.
    Probably too late to cancel gracefully...
    But you paid top dollar, IMHO. -assuming the cheaper ones are built as well as yours. However 4000+ lumens is not to be sneezed at and they make a point of 'no radio interference' generated. Might be another plus for you.
    olbod Guest
    Thanks for the reply's.
    No I will not cancel the order, I bought them in good faith so I will give them a go and let you know the result.
    Bloke next door has one on his Prado and he reckons it is brilliant, tho his is a 24" Great White with 6000 lumens.
    It would have to be an improvement on my poor old globed headlights.
    Even on high beam you can see the banana shaped bow as as the poor old beam falls to the ground.
    I could of course spend a lot of money and fit la de da new headlights but I thought that a light bar could be transferred to another vehicle if I wanted to.
    Mar 2007
    South Arm, Tasmania
    The one under the roofrack is a 40 inch Baja Stealth bar - it's rated at 16,800 lumens. Works extremely well.
    Once you've tried one, you won't want to drive anything without at night.
    Cheers .........
    BMKAL
    Mar 2012
    Armstrong Creek, Qld
    Umm! Just remember one bar is not legal in Qld if front mounted. You need 2 or tape out the middle so there's a gap. Can't remember the distance, sorry.
    Steve
    Quote Originally Posted by Saitch View Post
    Steve
    Must have been lucky all these years in my 110 then. I have a 20" mounted in my bull bar which has been there for 2 years and no one has ever said anything to me. Plus see loads and loads of them on qld roads with out the tape
    95 300 Tdi Defender 90
    99 300 Tdi Defender 110
    92 Discovery 200tdi
    50 Series 1 80
    50 Series 1 80
    www.reads4x4.com
    Apr 2002
    Bellara 4507
    32.43 MB
    Quote Originally Posted by Reads90 View Post
    what Saitch says is true.
    mate got pinged for it and that is what he was advised to do... so he put 50mm tape wrap around the center of it and happiness was attained.
    2007 Discovery 3 SE7 TDV6 2.7
    2012 SZ Territory TX 2.7 TDCi
    Sep 2012
    NSW
    I guess that's so. It's surprising that he put a 50mm tape, I would have reacted differently
    Just FYI - several GW light bars have now suffered cascading failure across the arrays.
    18mth to 2 years and it seems to start.
    Several cheaper units are running like this.
    And I have posted before - theoretical lumens from the emitter do not represent the real world output of these bars...
