9th September 2013, 09:04 PM
Radio buttons no working in D4
Good evening all,
I have a D4 poverty pack and tonight I have had the misfortune of the radio working, but not being able to change the station, or select any other function.
I can make a phone using the phone handset, but cannot use the radio buttons to make the call. The radio can be turned on/off and the volume adjusted, but on the unit only. The steering wheel radio functions do not work either (head unit).
Any thoughts, has this happened to you before?
10th September 2013, 07:39 AM
Probably not the same thing, but I had a problem with mine one morning a couple of weeks ago on the way to work. Radio would not work on any channel - no sound at all. Even on AM - there was no static.
Music streamed from iPhone worked as normal, and phone worked as normal through LR stereo.
Checked when I got in the office to make sure that radio stations were still "on air" and all was normal in the office.
So ............. thought I might have been up for a visit to the dealers for a replacement radio unit.
But when I drove home that night, everything working as normal, and no problems experienced since.
Must have been that Chinaman again ..............................
Cheers .........
BMKAL
10th September 2013, 11:35 AM
Well, the car slept on it last night, thought about its actions and decided that it would be in it's best interests to start working again?!
I tried on/off last night and it was being cheeky really.
10th September 2013, 11:53 AM
#4
How's your battery? Do you do long trips?
Load test your battery ;-)
