Thread: Discorosscv
    May 2013
    Mackay Qld
    Unhappy Discorosscv
    Hi Guys,just purchased seatcovers for my Disco4 HSE. Can anyone help me with info on how to remove my seat armrests. I have removed the hex screw but unable to slide armrest away !!! Is it possible that mine is just tight or!!!! M not quite ready to get the crowbar n start levering yet. HELP???Regards Ross.
    Jul 2009
    Anyone got any ideas on this?
    Terry
    D1 V8 (Gone)
    D2a HSE V8 (Gone)
    D3 HSE TDV6 (Unfortunately Gone)
    D4 V8
    Ean Austral Guest
    Maybe a call to someone like TRS. Looked on my D3 disc and doesn't tell you about them.
    Cheers Ean
    Simple, remove plastic cover on side of arm rest (pivot point) This hides the bolt that holds the arm rest to the seat. From memory it is a Torx bolt.
    To adjust arm rest sitting position there is a knob that winds a grub screw under the front of the arm rest, make sure this is loose (read wound all the way out)as it will hold the arm rest while trying to remove.
    HTH Cheers
    Sent from my iPad using Forum Runner
    May 2013
    Mackay Qld
    Disco 4 armrest removal
    Thank guys, I figured it out >>>mine were just a wee bit tight. After removing the torque head bolts,then a quick call to my local Land Rover Mackay w/shop tech. Charry,he said just use a bit 'o force n it will pop off. All done.
