Results 1 to 10 of 12
Thread: Recovering a D3/4/RRS
    May 2010
    Brisbane, QLD, Australia
    Hi Guys,
    This has probably been mentioned but I can't find it when I search.
    Scenario....
    You're in the middle of rough terrain and your engine doesn't want to play. A Flat Bed cannot get to you. Can you actually tow a D3/4/RRS safely without buggering anything?
    Kev.
    Sep 2011
    Echuca (Vic)
    Never had to be in this situation, but if you are being towed out I have been told to keep the engine running and in neutral, this is to keep the transmission fluid circulating around the gearbox. Happy to be corrected by people wiser than me on here though. Probably best to not tow it for too long if you can avoid it, but in that scenario- there is no other option really!
    Apr 2012
    Don't LR Assist provide a helicopter recovery service?
    May 2010
    Addition
    Oh I forgot to mention...
    I know about the transmission release to get the car in Neutral with no engine running but does this mean the car can now be towed?
    If yes, how long can you tug the thing for without damaging something?
    Ean Austral Guest
    Quote Originally Posted by Celtoid View Post
    Do tell about the trans release, never even thought about this scenario.
    Cheers Ean
    Hi Guys,
    Kev.
    Your handbook is your friend - if in doubt read the instructions . Is in the driving section just after towing. The car can be towed for a max of 50km in neutral at a max speed of - can't remember (50 kph I think).
    sheerluck Guest
    Quote Originally Posted by Ean Austral View Post
    Cheers Ean
    Underneath the trim where the gear selector is, there's a small white tab. Press that down.
    Feb 2013
    Ballarat,Vic,Aus
    If they have a proper transfer case, couldn't you just shift it to neutral, ie: between low & high range. This would prevent drive being transmitted to the gearbox.
    sheerluck Guest
    Quote Originally Posted by DoubleChevron View Post
    It's electronic. You get the choice of selecting high or low only on the switch, no lever.
    May 2010
    Right, would you believe:
    1. Men cannot read instructions
    2. I have no Handbook.
    3. It is not covered in my version of the handbook.
    4. My dog chewed those pages.
    5. I was taken off track by the fact that I remembered the unlocking of the transmission without power is NOT covered in the handbook.
    6. I haven't read it in 3.5 years and I had forgotten...
    Anyway, as Garry has so rightly pointed out, page 268 of my D4 handbook covers towing when electrical power is still available. In that case you just turn on the ignition, apply footbrake and select neutral. Do not exceed 50klms or 50kph.
    If you have no electrical power follow the advice and links that are in this thread and the FAQs to manually unlock the transmission.
    Cheers Gary,
    Kev.
